B&M drain plug question
Old Jun 9, 2010 | 12:55 PM
pulpwood007's Avatar
Where is the best location to install a B&M drain plug in the pan of my '05 CTD 48RE transmission.
thanks,
Old Jun 9, 2010 | 01:01 PM
Alpo's Avatar
I placed mine in the aft L/H corner....
Drivers side rear.
Old Jun 9, 2010 | 03:12 PM
Thanks for the reply. I would have guessed a little forward on the drivers side. This position looks as though it would miss the filter a little better.
Any type of sealant needed between the nylon washer and pan?
Old Jun 10, 2010 | 12:48 PM
Alpo's Avatar
No sealant needed...
Once you remove the pan, you`ll see a clean/clear location to mount it.
Had mine on now for a year or so....no leaks at all.
Old Jun 10, 2010 | 05:22 PM
no_6_oh_no's Avatar
Passenger side of pan 2/3 to 3/4 back on the side of the pan is the best place to install drain plug.
Use high temp sealant on both sides of plug, wipe off excess when tight, and let it set up before installing pan for best results.
Old Jun 10, 2010 | 05:34 PM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
No need for sealer. BUT..... replace the nylon washer with a copper one and tighten like your serious. The nylon slips and slides and crushes easily and can lead to adventures later when removing and installing the 1/8" plug....
Old Jun 21, 2011 | 06:51 PM
unbob's Avatar
OK, maybe a stupid question ... install the washer on inside or outside the pan?
Old Jun 21, 2011 | 07:15 PM
no_6_oh_no's Avatar
No need for sealer....
Oh, but the need for selaer is obvious by your own description. With a nylon washer the selant will stop all that sliding and moving and it works just as well with copper.
That way, you don't need all this serious cranking and tightening. You do that too much and you WILL strip the threads on the drain. Nothing ever pulls down exactly right and the heat cycles will almost always shift things. The sealer takes care of that.
Old Jun 22, 2011 | 08:35 AM
truckbouy2's Avatar
"OK, maybe a stupid question ... install the washer on inside or outside the pan?"
I put mine on the outside.
Old Jun 22, 2011 | 10:53 AM
NavyDood's Avatar
Weld it on and solve all your problems.
Old Jun 22, 2011 | 12:02 PM
truckbouy2's Avatar
"Weld it on and solve all your problems."
Best darn answer out of the whole pontificating thread...
Old Jun 22, 2011 | 10:04 PM
unbob's Avatar
Yup, me too. There aren't really enough threads on the inside to permit use of a washer. Just enough threads for the nut.
I also used a copper washer and hi-temp sealant.
Old Jun 24, 2011 | 08:13 PM
Mr Jerry's Avatar
Thumbs up
Yes I have to say just weld a nice thin axle type nut on the outside of a hole you drilled in the pan and a nice short bolt with a copper washer and your set.
mattzram
Oct 1, 2006 04:18 PM
ckennedy
Jun 16, 2006 04:14 AM
Steve034x4
Dec 12, 2005 08:21 AM
sajigore
Nov 10, 2005 08:19 AM
betsycam
Sep 20, 2004 07:20 PM
