Axle oil capacities?
Can someone tell me the capacities for the front and rear axle's? I cant find it anywhere in the manual. I've decided to go with redline heavy shockproof 75w90 in the back and redline 75w90 in the front, and I wanted to be sure I ordered enough.
info from
SERVICE MANUAL
2004
RAM TRUCK
1500 - 2500 - 3500
FRONT AXLE ± .03 L (1 oz)
C205F 1.66 L (3.5 pts.)
9 1/4 AA 2.25 L (4.75 pts.)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.32 L (4.9 pts.)***
10 1/2 AA 2.25 L (4.75 pts.)
11 1/2 AA 3.62 L (7.65 pts)
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip
Additive.
** Includes 0.9L (1.0 qts.) for coolant reservoir.
*Nominal refill capacities are shown. A variation may
be observed from vehicle to vehicle due to
manufacturing tolerance and refill procedure.
conditions.
SERVICE MANUAL
2004
RAM TRUCK
1500 - 2500 - 3500
Additive.
conditions.
I just changed mine last night with Red Line. It was exactly 4 quarts in the rear (11.5) and didn't take all of 3 quarts in the front (9.25).
This was my first differential oil change and I've got about 70k on it. I took the rear and unbolted the complete cover to see if I saw any particles laying around. Everything was really clean and the oil didn't look bad at all. The filler plug magnet had junk on it, but that was all.
The front was the same - fairly clean looking oil and junk on the filler plug magnet.
I've read a lot of people talking about how much junk would be laying around due to break-in or whatever, but mine wasn't the case.
But like I said, it was 4 quarts in the rear and right at almost 3 in the front.
Yup, you should fill 'er up until it starts to dribble out the fill hole, then plug it. The Redline oil should work great. I have had good luck with their stuff in the past. When my NV5600 fluid needs changed I will be putting Redline in there.
I'm a newbie, but from my reading on the diff's. There to be filled within a 1/4 inch of the bottom of the fill hole +/- 1/4 inch. So that would put you to the bottom of the fill hole on the + side.
I'm sure someone will correct me if I misunderstood what I've found on these forums.
There were two different levels that were being posted before, the front and rear were different IIRC. Filling to the bottom of the hole was within spec on the rear but not technically the front I think. The amount extra wasn't probably significant enough to cause any serious foaming I would think, but why put extra in when you not supposed to?
D45
Nov 12, 2007 11:24 AM
dodgezilla04
Mar 13, 2007 12:42 PM
Don Shearer
Sep 16, 2004 03:12 PM
rossn2
16
Feb 5, 2004 10:05 AM
