Oil Fill Capacities for 2004
Old Jan 19, 2004 | 10:36 AM
rossn2's Avatar
Does anyone have the oil filter capacities for 2004 2500 Quad Cab 4x4, HO Cummins? NOthing in owners manual...
1) Frt and Rear Axles (4qts each ??) Mopar GL -5 75-90w
2) Transfer Case ( Depending on which one it can hold up to 3.5 qts???) Mopar ATF+4
3) 6 spd NV 5600 (8 qts???) Mopar 4874464
Getting ready to change to synthetics///
Old Jan 19, 2004 | 11:16 AM
Jeff in TD's Avatar
At least on an 03:
Front axel is 4.75 pints
Rear axel is 7.65 pints
MV6500 6 speed is 9.5 pints
Transfer case I believe is 4 pints
Figure 7 quarts of 75-90 for the axels, I suppose.
5 quarts for the tranny,
and two quarts for the transfer case.
Old Jan 19, 2004 | 11:59 AM
Haulin_in_Dixie's Avatar
MV6500 6 speed is 9.5 pints ??
Is this a misprint or is it a new trans ?
Old Jan 19, 2004 | 02:45 PM
rossn2's Avatar
Has anyone used RED LINE Oil products?
Old Jan 19, 2004 | 06:19 PM
Jeff in TD's Avatar
Haulin_in_Dixie,
My bad, I meant NV5600. "MV" was a typo.
If you meant the capacity seemed wrong, if I recall, wasn't the NV5600 redesigned for 03? Book says 8.0 pints for NV4500, and 9.5 for NV5600...
Perhaps someone who is more of an expert will chime in...
Old Jan 19, 2004 | 09:37 PM
bulabula's Avatar
The '03 DRM says the NV5600 capacity is 9.5 pints.
I put in about 9.5 pints in mine when I changed it out a couple of months ago (almost 5 quarts).
BTW, for the NV271 Xfer case, the book calls for 4.0 pints, but mine took a little over 5 pints - I bought 3 qts and had some left over.
Old Jan 19, 2004 | 10:15 PM
Jeff in TD's Avatar
BulaBula
Interesting. My transfer case was most of a quart below the fill hole from the factory, and I was wondering if that was low enough to cause problems later... considering it is apparently only supposed to take two quarts.
Old Jan 19, 2004 | 11:07 PM
bulabula's Avatar
Jeff, I don't know, but others have also reported the same thing - xfer case and/or tranny being low.
That was one of the reasons why I changed everything when I did - now I know that everything is topped off as it should be.
Old Jan 20, 2004 | 12:22 AM
Big Bob's Avatar
I used Redline MT-90 in my 99 5-speed. It made a big difference. Before I used it, I always had a hard time getting in to reverse and 1st. After the use of Redline, it was much better!
Old Jan 20, 2004 | 07:14 AM
bulabula's Avatar
I was going to run MTL in my tranny, but my local vendor ran out when I was ready to buy. Amsoil is in there now - I'm happy with it. There's a number of folks running MTL in their tranny's and reporting good results also. I may try it next go around.
I do have MTL in my Mustang 5-speed tranny and enjoying every moment of it.
Old Jan 20, 2004 | 11:19 AM
rossn2's Avatar
"..was going to run MTL in my tranny, but my local vendor ran out when I was ready to buy. Amsoil is in there now - I'm happy with it. There's a number of folks running MTL in their tranny's and reporting good results also. I may try it next go around.
moment of it. "
I just ordered the MTL on-line(7.00 per quart) for the Tranny (...And, ordering everything else in Amsoil....except oil & Fuel filter (Stratapore)...Plan on changing oil filter at 7500k and oil/filter at 15k...Still under warranty.... I'm waiting for correct part number from AMSOIL on FOAM AIR FILTER ASSEMBLY..it's either the TS 106 OR TS 189...
Oh, retired CPO HERE!
Old Jan 21, 2004 | 06:10 AM
rossn2's Avatar
Commando....here, from another post I answered...
I'm changing shortly (as soon as all arrives)
Engine: Amsoil 15-40w Heavy Duty Diesel and Marine Oil and will be running the Stratapore Oil Filter (LF-16035). Will change oil filter at 7500 miles and then oil and filter at 15k. This way I'm covered by both A & B Schedules in my owner's manual.
6 spd Transmission - REDLINE MTL ( cause it's specifically made for transmissions) Cheapest I found $7.00 a quart at
http://www.myoilshop.com/AutoPrds.html
Frt and Read End: Amsoil Series 2000 75w-90 Gear Oil
Transfer Case: Amsoil Universal Auto Trans Fluid
Air Filter: FOAM AMSOIL, TS 189 for 2003 & 2004( confirmed 21JAN04)
Fuel Filter; FleetGuard FS 19579...
Oil Filters and Fuel Filters coming from Geno's Garage at the 4/2/1 kit... http://www.genosgarage.com/
Only 6000 miles on my baby!
Old Feb 4, 2004 | 11:57 AM
Nitro71455's Avatar
TTT this is good info.
