Automatics with boost gauge?
Old Jun 9, 2006 | 07:52 PM
Tree DR's Avatar
Is it normal to max out boost 22psi+ everytime you take off from a stop? I'm not talking about raceing either. Just a normal take off, not real slow but not real fast either. The truck I'm talking about is a stock 05, 3500 SRW, 4x4, 3.73, auto.
Tree DR
Old Jun 9, 2006 | 09:01 PM
bigwheels94's Avatar
Sounds pretty normal to me.I hit 19-25 psi. a lot whan I'm getting on it a little.(1/2 throttle+/-)You'll hit 30ish. when you punch it.(You'll also probably fry the rubber too when you do that.)
Old Jun 9, 2006 | 09:02 PM
Begle1's Avatar
Tree DR
Pah...
When the boost gauge gets to 22 PSI, that's when you know to take your left foot off the brake...
Old Jun 9, 2006 | 09:44 PM
Tree DR's Avatar
I've not driven a automatic. And this was not power braking. It's a stock 05. With my 6spd I never hit max boost even with the Edge on unless I stick my foot in it. If the torque converter is real loose on a auto could that cause the max boost since it takes more fuel to get it to move?
Old Jun 9, 2006 | 11:24 PM
RonP's Avatar
I never see more than 10psi when I am pulling away from a red light unless I am trying to get into it hard. something isn't right if you are pulling that kind of boost just to get moving.
Old Jun 9, 2006 | 11:44 PM
06Cummins's Avatar
at around 20 psi i have my foot into it pretty good at about 2k rpm accelorating...about 8-10 psi is normal for me not trying to get anywhere in a hurry and save some gas...i hit 34psi wot and it settles to around 30-31...jason
Old Jun 10, 2006 | 12:13 AM
StrokeThisCTD's Avatar
on regular accelleration 2200 RPM or so i can hit 22PSI. i thought it was high too, but oh well. It goes down to 6lbs quick when i get crusing on the highway.
Old Jun 10, 2006 | 02:36 AM
Its All Good's Avatar
I can get it up to 20 psi +/- from a stop light if I get on it a little, and that's not racing. But it will come down after I hit crusing speed.
Old Jun 10, 2006 | 02:58 AM
Badd Dogg Guy19's Avatar
I have hit 31-32lbs with my bone stock w/ 3.73's. If I'm on the x way, and getting upto speed, I can do around 30-40 mph, than push it to the floor, sh'ell kick down, and the boost will go right up to at least 30lbs. I usually wait to do that untill I get a ricer or something in that nature, with his window down, ususally when his drivers window is near my tailpipe, I love watching them in my rear-veiw, waving their hands back and forth, trying to fan the cloud of black smoke out of their cars!!
Old Jun 10, 2006 | 09:47 AM
wexman's Avatar
My 2004.5 will max at 32 lbs WOT up hill, then back off to about 28.
Old Jun 10, 2006 | 11:24 AM
BigBlue's Avatar
Mine sees about 10 psi normal driving and 45 at WOT.
Old Jun 10, 2006 | 07:55 PM
Tree DR's Avatar
If the torque converter is to loose that would be a possible cause of max boost. For instance driving at 65 and going up a slight grade with the cruse on it will hit max boost.
How to get the dealer to fix it? It's only loose not broken. Lousy fuel mileage isn't their problem.
ckennedy
Oct 30, 2004 03:32 PM
ckennedy
Oct 17, 2004 06:10 PM
Happy Traveler
Dec 14, 2003 07:39 PM
routerguy99
Sep 1, 2003 06:56 PM
29
Apr 13, 2003 08:36 PM
