Air type sound on higher boost
Old Jan 16, 2009 | 02:35 AM
rbox's Avatar
When I get on the throttle hard I am getting an air sound from under the hood. When it does this my power levels off, I guess it is not building boost at that point. I fixed a boost leak recently by tightening up the clamps to the intercooler - could it be a different boost leak or is that just my wastegate opening?
Old Jan 16, 2009 | 08:47 AM
FMB's Avatar
FMB
You guess pretty good. Check for split air ducts and/or split intercooler.
Old Jan 16, 2009 | 03:55 PM
bradler's Avatar
Pretty easy to test turbo all the way through intake manifold for boost leaks with a cheap homemade boost tester, works well, i just found a leak on mine at intake manifold plate. Do a search and some people have pics of what i'm talking about, basically a 4in to 3in rubber coupler w/ hose clamps to go over turbo w/ 3in pvc cap in other end that is threaded for a shrader valve. charge system to 20 psi and listen for a leak.
herb
Jul 18, 2008 08:25 AM
kram
Aug 29, 2007 11:01 AM
CRXsi
Mar 31, 2006 07:56 AM
jerry007
Oct 28, 2004 08:24 AM
ratsun
Jun 12, 2004 12:04 AM
