Adjusting the valves?
Old Dec 12, 2006 | 08:40 PM
dodgepower88's Avatar
Well, My truck has 118,000 miles on it and i've heard rumors of people getting the valves adjusted on their trucks after a while. My question is can I do it, and if I can should I wait or do it soon. I like my truck and want to be very good to it.
I am the third owner of my truck and don't know if the previous owners went this far into the maintenance thing.
PS: I don't think anything is wrong, just being cautious.
Old Dec 12, 2006 | 08:59 PM
dieselfan's Avatar
YES do it, its a nice piece of mind. it could help with your mpg. someone will chime in with specs.
BTW you have a 48re.
Old Dec 12, 2006 | 10:20 PM
Jeff in TD's Avatar
If the gap is within range (Intake is 0.006 to -.015 and exhaust is 0.015 to 0.030 with cold engine) then no adjustment is needed... If out of that range, then set intake at 0.010 and exhaust to 0.020.
Remove the valve cover, rotate the engine with a barring tool or by the alternator pulley until the TDC mark on the damper is at 12 o'clock.
If both #1 valves are loose then #1 is between compression and power stroke, so adjust intake on 1, 2 and 4 and exhaust on 1, 3 and 5. Feeler gauge goes between the rocker arm socket and the crosshead.
If both valves on #1 are not loose it's in overlap between exhaust stroke and intake, so you adjust intake on 3, 5, 6 and exhaust on 2, 4 and 6...
Then rotate the engine 360 and do whichever group you didn't do...
My guess is that you will find none out of range, but for peace of mind I'd check them...
Old Dec 13, 2006 | 07:31 AM
HOV's Avatar
HOV
Do the CTD valves have locknut style adjusters?
Old Dec 13, 2006 | 08:15 AM
MikeyB's Avatar
Yes.
Personally I would go ahead and set all to 0.010 and 0.020 even if they where in spec.
MikeyB
Old Dec 13, 2006 | 08:17 AM
HOV's Avatar
HOV
Originally Posted by MikeyB
Yes.
MikeyB
Was that a 'yes' to my question?
If so, I'm surprised they stay in adjustment so long.
Old Dec 13, 2006 | 09:03 AM
MikeyB's Avatar
Yes, threaded adjusters.
MikeyB
Old Dec 13, 2006 | 09:06 AM
Thanks for the info guys
I think i'll get it done soon.
Old Dec 13, 2006 | 09:24 AM
PourinDiesel's Avatar
Make sure you guys get a barring tool so you can get the engine in position to be able to do the valve lash adjustments.
Old Dec 13, 2006 | 03:11 PM
Jeff in TD's Avatar
Yeah, that's probably what I'd do, too, but I thought I'd post what the bookk says.... that as long as they are within range there is no benefit to performance, noise or fuel economy to be gained by messing with them.
If you do adjust one, after adjusting tighten the lock nut to 18 ft/lbs and recheck lash.
marine4life
Mar 11, 2006 08:36 PM
robox
Aug 16, 2005 07:27 PM
CrewCabCummins
Jan 3, 2005 04:29 PM
Denis
Apr 19, 2004 12:32 PM
Puke
Jun 23, 2003 01:06 PM
