AC Leak
Old Jul 13, 2008 | 07:59 PM
jpajax's Avatar
AC Leak
Is there a favorite place that that I could look too see were 134 is leaking.
Old Jul 13, 2008 | 09:18 PM
BigIron70's Avatar
Cummins Guru
Compressor seal, evaporator, condenser or hoses. Have AC dye injected into system and have it checked when it stops cooling or in a week. Depends on how big a leak you have. Black lite and UV glasses are needed, if evaporator is leaking dash needs to come out to replace.
Old Jul 13, 2008 | 09:24 PM
mrblond's Avatar
I would check all the air line coupling nuts since I found a loose one to the evap canister once. I got off easy that time.
Another basic test is to short out the pressure switch on the evap canister to get the compressor turned on. But these are checks I would make on my older trucks and Im not sure if they carry over.
good luck
Old Jul 13, 2008 | 10:03 PM
jpajax's Avatar
Thanks will check fitting out tomorrow.
zig100
Mar 18, 2010 03:39 PM
george7941
Nov 28, 2009 09:28 PM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
