Broken G56
Old Jul 12, 2008 | 01:02 AM
JSCC's Avatar
Broken G56
Well I think I have lost my 6spd. Heavy towing and some extra go juice, and she didnt make 50 thou.
Anyhow, need some advice on getting a new one, getting this one fixed, or going with an aftermarket setup.
Kind of blows, I bought this 6 spd thinking it could take what my 48re couldnt....... guess I was wrong. I might just need more truck.
Thanks for any advice.
Old Jul 12, 2008 | 01:22 AM
RollOver Pete's Avatar
What about your warranty?
Does your truck have one?
Filling out you're signature might make it easier for someone to answer your question.
Old Jul 12, 2008 | 06:22 AM
Jeff in TD's Avatar
I think the last time I strolled through the classifieds, there was a new in the box G56 for 4x4 at a good price...
Old Jul 12, 2008 | 08:09 AM
snoyes's Avatar
What actually broke in the transmission?
Old Jul 12, 2008 | 10:06 AM
wmonroe's Avatar
How heavy were you towing? How much power are you running? Was there any signs of problems at last fluid change?
Will
Old Jul 12, 2008 | 04:49 PM
Jim Dynomite's Avatar
I looked in your profile to see your truck and after reading through some of your previous posts, I noticed you pull 38,000lbs quite often and you hold it at 1500*F or higher for extended periods of time..............
I'd say you got lucky that's all you broke.
Try looking in the sled pulling and competition forums for advice on after market stuff.
You're right about one thing............... you might need more truck!
............Jim
Old Jul 12, 2008 | 05:00 PM
mrblond's Avatar
so how long did the 48 last
Old Jul 13, 2008 | 02:37 PM
JSCC's Avatar
Sorry for the delay.
Yes, I do pull 30,000lbs often, with the truck 38,000lbs. My camp trailer alone is 17,000 loaded.
I still have the 05' with the 48. I had it rebuilt at 40,000 miles or so. Then started looking for a truck with the 6spd. It lasted about 35,000 before the clutch, then it has started going down hill from there. This truck is used 95% of the time to pull, so yes, it gets used.
I am sure there is a warranty on the truck as it was stock, but not how it is now. So this one will be on me, and then I am afraid the truck will be sold.
As for what broke I dont have the foggiest. I will be looking into it this week. Loud clunking from all gears but 5th. In fifth she still sounds nice and quiet.
Has anyone heard that before?
Old Jul 13, 2008 | 04:32 PM
Jeff in TD's Avatar
5th gear being direct, I'd presume there wouldn't be any load on the countershaft and related gears, and less of a side load on the main shaft?
Anyway, it might be worth tearing it down to see if it is an easy fix. Otherwise I think I'd see if that one that was in the classifieds is still there.
Old Jul 13, 2008 | 04:52 PM
snoyes's Avatar
Maybe time for a semi instead of a pickup truck....
Old Jul 13, 2008 | 09:57 PM
JSCC's Avatar
Thats kind of what we are thinking at this point.......
Jeff in TD, thanks. I will get it torn down and see before I lay down some money. Maybe I got lucky....
Old Jul 13, 2008 | 11:11 PM
GlennRMK's Avatar
At least upgrade to a new 5500!
NoSparkplugs
Apr 30, 2008 11:27 PM
Rpainter
21
Mar 8, 2008 02:36 PM
TXTad
Jan 24, 2005 07:23 AM
Mexstan
Sep 8, 2004 10:52 PM
