7 micron hard on lp?
Old Dec 11, 2006 | 02:26 PM
mule3010's Avatar
Does anyone feel that the additional restriction created by the 7 micron fuel filters places a strain on the LP?
Joe
Old Dec 11, 2006 | 03:01 PM
lamadera's Avatar
Good question. I just installed my last 10 micron and I'm going to order a few of the new 7 micron. I don't want to get stranded with a dead lift pump. I could install a FASS or GDP pump, but I have a lot of warranty left and I don't want to void it, especially with all the injector issues. So what do ya do?
Old Dec 11, 2006 | 03:26 PM
bigdav160's Avatar
Joe
Personally, I think 7 micron is less of a restriction. Smaller holes but many more of them.
Old Dec 11, 2006 | 03:33 PM
johnh's Avatar
compare the flow rate, that should say something
Old Dec 11, 2006 | 03:59 PM
Spooler's Avatar
When I changed from 10 Micron to 7 Micron I didn't see any fuel pressure change after the filter. Dosen't say much for the volume but you would think pressure would give you a tell, tell sign of an added restriction.
Old Dec 11, 2006 | 04:59 PM
CD in NM's Avatar
I did not see any fuel pressure change when I went to the 7-micron either. I did not see any change when I installed the GDP 2-micron. I also installed the big line kit with the 2-micron setup and since fuel pressure IS about volume I did not expect a change. The 7-micron does have a better flow rate and the 2-micron is in the same range.
CD
Old Dec 12, 2006 | 10:36 AM
motrapper's Avatar
what is a GDP filter and where did you place it in the fuel system
thanks
Old Dec 12, 2006 | 11:09 AM
trik396's Avatar
Well, I can tell you if I still had my stock pump, I'd have been stranded already. I hadn't used an additive for awhile and it dropped in the single digits for a couple days... My 20-25psi became 2psi. If it wasn't for the power of the EFI pump, and if I had my stocker, I know it wouldn't have been able to push thru the gelling I was seeing. Just a thought...
Old Dec 12, 2006 | 11:25 AM
RankRam's Avatar
thanks
http://www.glacierdieselpower.com/pr...=MK20306%2DBLK
Here it is, I just installed mine last night. It took me 2.5 hrs and I wasn't in a hurry. Fuel pressure still looks good, I'm guessing I have lost 1-2 lbs.
It's a very nice setup, it goes between the stock 7 micron filter housing and the Cp3.
I'm saving for the Walbro kit!
Dargo
Jan 12, 2018 07:45 PM
LUKE-MM-PULLER
Oct 31, 2010 09:35 AM
03RAM2500
Jan 11, 2009 05:21 PM
Lightman
13
Jun 16, 2004 11:53 PM
Chillimau
Jun 16, 2004 07:10 AM
