2005 fuel return ?
Old Dec 26, 2009 | 08:47 PM
winkdemon's Avatar
2005 fuel return ?
having a problem with a no start on a 2005 , at the cp3 when i crank it should ihave fuel coming out of the return line ? i am not building rail pressure and i am wondering if this is why ?
Old Dec 26, 2009 | 11:58 PM
winkdemon's Avatar
no one have answer to this ?
Old Dec 27, 2009 | 09:37 AM
no_6_oh_no's Avatar
You could have if the CP3 makes over 75 psi of internal pressure while cranking.
Does it start flowing from the return right away or does it take a bit to start returning fuel?
Old Dec 27, 2009 | 12:04 PM
winkdemon's Avatar
starts flowing right away , and it's not building rail pressure
Old Dec 27, 2009 | 02:43 PM
no_6_oh_no's Avatar
Is the flow you are seeing only the pump?
In other words, did you isolate the injector return from the pump return so you can tell where the flow is from?
High injector return will negate rail pressure building also.
Old Dec 27, 2009 | 11:04 PM
winkdemon's Avatar
yes i took the line off at the cp3 and it comes out of they as soon as you crank the truck . so is that mean FCA ? i have a no start no problem , the truck was runnnig then just died .... and have no codes
Old Dec 28, 2009 | 08:10 AM
no_6_oh_no's Avatar
Pull the wiring plug off the FCA and try to start it. That should throw full pressure to the injectors and see if it will start. If it does it could be the FCA is stuck closed. If it doesn't start it is probably something else.
The COV controls fuel to the return circuit, thats the black culinder with what looks like a ball in the end of it.
I hesitate to say take the rail line loose from the CP3 because that is pretty high pressure but if your careful and don't crank it too much you should be able to see if it is presurizing the rail.
Do you have a rail pressure gauge and its not showing pressure?
What mods do you have to engine?
Have you checked the rail pressure relief valve to see if it is stuck open?
Old Dec 28, 2009 | 10:56 AM
winkdemon's Avatar
i tryed the wire off the fca , made no differents , but when it's off and i shack it it's really hard to hear the ball inside of it .
no i don't have pressure gauge , and can't seem to find one i can use .
engine is stock , right done to the air box
and i checked the rail relief seems ok , no fuel is coming out of it .
Old Dec 28, 2009 | 12:05 PM
no_6_oh_no's Avatar
ISSPRO EVA2 series rail pressure gauge is a nice unit and easy install. DiPricol also has one.
Shaking the FCA is not always an indication it is bad, just happens that way sometimes. Either you will need some gauges or a scanner to see what the ECU is demanding as opposed to actual, or start replacing parts. The FCA is around $120 and a definite possibility.
Its tough with a no run condition to track the problem.
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
shortround
Jun 25, 2005 10:28 AM
shortround
Feb 5, 2005 08:40 AM
