2004.5 fuel pressue gauge
Old Aug 15, 2007 | 06:37 PM
ez_lle71's Avatar
Hello,
I was wondering if i need to install a fuel pressure gauge on my 04.5'? What would be the advantages of having one? I know the 2nd gen 24v's had lift pump problems, Do the new common rails have the same problem? Thanks
ez
Old Aug 15, 2007 | 08:30 PM
SAS's Avatar
SAS
My 04.5 lift pump went out at 52k. I was planning on putting in a FP guage but hadn't done it when the LP went. Some say you may not see a drop in pressure they just go? others say they saw low pressure right away. My Lp was replaced under warranty with the in tank "upgrade"? I hope it holds up better? I'm thinking about adding an in line pump to help it out. I installed my FP guage and the in tank holds 9-10 psi at idle and 7-8 psi wide open but I haven't towed with the new pump yet?
Is it true that anything above 5 psi is ok? My truck is basically stock.
Old Aug 16, 2007 | 03:07 PM
PEAKSTRYDE's Avatar
I just got my truck back from the dealer Tuesday afternoon. Mine went out Monday morning with only 50K on it.
I called Larry (top) yesterday and my fuel pressure gauce its on its way. Also I'm still going to go with a Walbro pump, IMO its the best out there and there are very few problems if any once installe on out trucks.
This is a good, helpful thread if you have not already seen it.
http://https://www.dieseltruckresour...d.php?t=152569
Old Aug 16, 2007 | 03:16 PM
coolslice's Avatar
I have a FP gauge and when my LP went south @ 30K there really was no way to know it was going to happen from looking at the FP gauge. IMO, a FP gauge is good to have for entertainment purposes, but there is no gaurantee that it will give you any advance warning of a sick LP.
dodgezilla04's Avatar
my factory l/p died at 12k.
Old Aug 16, 2007 | 04:06 PM
CTDinMT's Avatar
GDP-392! Helps me sleep at night!
03schoolbus
Dec 22, 2008 09:22 PM
stroker4501
Mar 16, 2008 09:24 PM
Fireslo04
Jan 21, 2007 10:20 AM
Buckshotmckee
Feb 7, 2005 10:24 PM
