Need quad rail pressue gauge help.
I just recieved a quad rpg from a site member and I am wondering if anybody can tell me which # fuse I need to tap.Also it has a black wire which I assume is a ground(should I go to battery or chassis?)and a brown wire coming off off the sender plug harness?
Any help would be great!! Thanks
#28 and the black sleved wire is for the optional FP gauge. Regular black wire to ground.
Make sure to install the quad harness first and then your pressure box harness if you have added pressure and then factory harness
ez_lle71
Aug 16, 2007 04:06 PM
973604x4
16
Jun 15, 2007 07:01 PM
