06 Problems
Old Dec 15, 2010 | 08:04 PM
  #31
Hvytrkmech's Avatar
My 06 has never done it. 0 deg out not plugged in and start it up it will go directly to 1000 rpm and stay there smooth as glass. If I use the cruise it will set to 1100 rpm and same thing, smooth as glass.
Old Dec 16, 2010 | 02:08 PM
  #32
modiesel's Avatar
Any update on this? Mine has just started doing it.
Old Dec 16, 2010 | 07:25 PM
  #33
critser660's Avatar
I would call mine more of a flutter every now and then, not an oversized cam lope, even with a new fuel filter.
Old Dec 23, 2010 | 03:43 PM
  #34
DBLR's Avatar
If you look at the tachometer and its not moving up or down and you hear what you think is a lope IMHO its some sort of harmonics from the engine or exhaust system. The only time I hear what some call a lope from my truck is if I don't let the grid heater run a full cycle when the outside temp is below 10 degrees and also I have not used the block heater.
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
