04 5.9 wont start with out either, running away
Old Sep 12, 2008 | 12:16 PM
norbergauto's Avatar
I have a 04 5.9 that wont start without either, once started it will just idle perfect. Once you hit the throttle, it will not slow back down. The rail pressure will not come back down once raised. Any help appreciated.
Old Sep 12, 2008 | 03:42 PM
alMout's Avatar
Could the high pressure return be clogged?
Old Sep 12, 2008 | 03:47 PM
LakeLife79's Avatar
Could it be a stuck FCA? Check your connection on the CP3 it might be loose. I'm pretty sure thats your problem. If your FCA is unplugged it will operate at full capacity causing high rail pressure. If its not loose I would look into getting it replaced.
Old Sep 12, 2008 | 04:09 PM
I haved replaced the fca, then i changed the cp3, same problem, any more ideas?
Old Sep 16, 2008 | 11:02 PM
jcarrillo's Avatar
I've got the same problem with a customers truck. Did you guys figure out what was causing the problem? I just agreed to work on the truck today.
Old Sep 16, 2008 | 11:05 PM
06RAM2500's Avatar
APPS could be faulty. Check for codes!!
Old Sep 17, 2008 | 12:28 AM
jcarrillo's Avatar
Thanks, I'll check.
Old Sep 17, 2008 | 12:44 AM
06RAM2500's Avatar
Cycle the key three times. On the 3rd time leave the key on and they'll show up in the odometer.
brokentoy
Mar 2, 2011 09:10 PM
commonrailkid04
Apr 27, 2008 02:03 PM
dv_shane
Feb 7, 2008 03:33 PM
rpeltier01
15
Aug 3, 2007 07:22 PM
Huff nPuff
Mar 5, 2004 11:28 PM
