'04 (305) wastegate question
Old Aug 25, 2008 | 09:04 PM
  #31
D45's Avatar
D45
HotRodK, did you "adjust" the screw all the way in before you installed the elbow?
I just looked at mine and the directions state that it comes adjusted all the was in, for max boost. However, I was able to screw the bolt down even further......
My two ply wastegate silicon hose arrived today. I just need to get two clamps for it.
I am going to install it next week, along with a 5 ply silicon intercooler hose kit, and my Icebox intake.
I will repport the boost numbers hopefully by the end of next week.
Old Sep 2, 2008 | 10:55 AM
  #32
alMout's Avatar
A cheaper fix than the elbow is to buy a fuel cutoff valve for a 1/4 inch hose. I got one from Advance Auto parts in their lawnmower section. It is a quarter turn valve so you can adjust it just like a boost elbow and it only cost $6. Cut the hose in the middle and install. I ended up closing mine completely and that gives me about 31 lbs max boost.
Old Sep 2, 2008 | 11:13 PM
  #33
ozpall's Avatar
are you guys running the quadz boost fooler too?
Old Sep 2, 2008 | 11:14 PM
  #34
D45's Avatar
D45
No, my Smarty JR boost fools to 44 PSI
Old Sep 3, 2008 | 05:56 PM
  #35
ozpall's Avatar
if you ended up closing yours completely, what's the point of buying some cutoff valve? just plug your hose then and that's it, isn't it???
Old Sep 4, 2008 | 06:06 AM
  #36
HotRodK's Avatar
Thumbs up
I didnt put an allen wrench on it, but I couldnt turn it more with my fingers. With the Bully Dog on Extreme, it runs REALLY well. Im very happy with the $20 spent!
Old Sep 4, 2008 | 06:51 AM
  #37
ozpall's Avatar
how much boost are you seeing? do you have a boost fooler?
Old Sep 4, 2008 | 08:30 AM
  #38
D45's Avatar
D45
I am finally going to install mine this weekend..........I was seeing 22-24 PSI, so I will be able to report what numbers I am seeing after the boost elbow install.
Mine was also finger tight, as I think it is designed that way.........so it won't back out.
I was able to turn mine about 2-3 full rotations and tighten it down more.
I am also very pleased with the layered silicon hose I bought, it is very nice.
Old Sep 7, 2008 | 06:13 PM
  #39
D45's Avatar
D45
I installed my adjustable boost elbow today, along with a new 2 ply silicon hose and new hose clamps.
Before, I was seeing 22-24, with a rare 26 PSI.
After the install, I am seeing 36, 37, and 38 PSI.
I am pleased!..........nice uprade for a $20 and $15 for the clamps and silicon hose.
checkster
Oct 4, 2009 10:43 AM
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
flyfsh70
Aug 4, 2005 08:04 AM
