14 cm housing.... wastegate or no wastegate?
Old Feb 21, 2006 | 05:56 PM
ataboy9026's Avatar
My 98 has a 14 cm turbo exhaust housing and it doesn't seem as "snappy" as my 95 did. Both trucks have a #6 but the 95 was bone stock other than that, this one has mega air intake and 4" magnaflow and a 4k spring kit. Is there any thing I can do to give the throttle response or quick accelleration the 95 had? Should I put the stock exhaust housing back on? Or put a wastegate on it, the port has a plug in it now, I assume the previous owner plugged when he put on the 14 cm.
Old Feb 21, 2006 | 07:45 PM
plow's Avatar
slide your plate forward but make sure your govenor arm is adjusted right, slide yhe AFC full forward, Turn starwheel full forward other than that put some bigger injectors in there. I didn't see any of this stuff in your sig you might already have tried this.
Old Feb 21, 2006 | 08:59 PM
DESL PWR's Avatar
The wastegate will only limit your max boost provided by the turbo. Your lack of "snappy" power may just be the difference in lag from the 12cm housing to the 14cm housing. If you dont have any EGT issues and you dont plan on adding more fuel go ahead and try the smaller housing.
Old Feb 21, 2006 | 10:12 PM
plow's Avatar
the bigger housing is exactly whats causing his lack of power, your going to have to add more fuel to compensate for the bigger housing.
Old Feb 22, 2006 | 12:48 AM
plow's Avatar
If adding more fuel is out of the question right now, putting the smaller housing back on like DESL PWR said would help it spool alot quicker.
Old Feb 22, 2006 | 05:09 AM
infidel's Avatar
Make sure the afc housing is full forward.
93beater
Apr 11, 2007 06:37 AM
ajbirken
Sep 6, 2006 12:11 AM
wannadiesel
38
Sep 29, 2005 06:35 PM
95black2615
Jul 21, 2005 09:06 PM
HOHN
Dec 7, 2003 02:07 PM
