wastegate housing
Old Apr 9, 2007 | 12:56 PM
93beater's Avatar
wastegate housing
i'am totally in the dark about the pros and cons of wastegate housing, and which sizes are best, can any1 fill me in?!
Old Apr 9, 2007 | 01:09 PM
gman07's Avatar
The wastegate dumps exhaust flow around the turbine wheel to control the speed of the turbocharger's shaft, and thus limit boost. Wastegates allow you to limit boost to prevent blowing the head gasket as well as prevent excessive drive pressures (pressure in the exhaust manifold driving the turbine. There are external wastegates that mount on the exhaust manifold, and internal wastegates built into turbine housings.
Your truck either has the 18.5cm housing or the 21. If it's the 21, I'd ditch it and go with a smaller one.
Available for these trucks are: 12cm WG, 12cm NWG, 14cm WG, 14cm NWG, 16cm NWG, 18.5cm NWG, 21cm NWG
(WG=wastegated, NWG=non-wastegated)
As you go smaller, the spoolup will improve, but they also tend to "choke" earlier. The 16cm or 18.5cm are good all around housings, but they don't have wastegates. If you're going to go with a wastegated housing, get a 12cm, they're available much cheaper than the 14.
Old Apr 10, 2007 | 11:07 PM
93beater's Avatar
thanks tom sounds like a plan, there is a good looking one in the classafieds maybe take a look and tell me what ya thnik!!
Old Apr 11, 2007 | 06:37 AM
G1625S's Avatar
93, with the auto, I think you'd be $$ ahead upgrading your compressor housing before messing with the exhaust housing since you have an automatic. You can tune the AFC to spool the turbo reasonably quick. Most folks that go with the 12cmwg are running 5-speeds--we've gotta spool the turbo in every gear, whereas you can just mash it and go I think the 18.5 is a great all around housing, especially for an automatic.
sallyman1
Feb 10, 2008 06:17 PM
rbrettctd
Jul 11, 2007 09:57 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
wannadiesel
38
Sep 29, 2005 06:35 PM
