03 4X4 Front Wheel bearing
Old Aug 7, 2006 | 10:18 AM
Okie's Avatar
Angry 03 4X4 Front Wheel bearing
Right front wheel bearing making noise. Has movement by hand. Question??? Shouldn't this be covered by the powertrain warranty. Local dealers say no, but with only 46K I think it should be. Anybody ever had any luck with Dodge picking up the tab?
Old Aug 7, 2006 | 10:56 AM
Chip's Avatar
Okie,
I had mine replaced at 43k miles to the tune of $1300. I do agree they should be covered, but unfortunately they're not. Good luck
Chip
Old Aug 7, 2006 | 12:50 PM
RonP's Avatar
They are not covered, but you can get those bearings for a little over 200 a piece. Same d*mn bearing they wan't over 450 for. Prt number BR930502
http://www.ebatmus.com/search.epl?Query=br930502
good luck
Old Aug 7, 2006 | 01:36 PM
HappyGA's Avatar
Geeze RonP, where were you week before last? I just spent $450 on one of those expensive ones...
oh well, you live and learn, thanks for the link..It is added to my favorites now.
Old Aug 7, 2006 | 07:56 PM
dpmizell's Avatar
if you have the extended warrenty you can get it done for $50 a the dealer.
Old Aug 7, 2006 | 08:28 PM
Okie's Avatar
03 4X4 Front wheel bearing
Not a warranty item. No extended warranty.2nd owner. Call the 1-800 to double check. Tried hard saying attach to axle end, ie axle bearing. No luck Part 361.00 from dealer only and $150.00 labor. Lesson learned.
Old Aug 8, 2006 | 12:01 AM
ptgarcia's Avatar
The unit bearing is considered a wear item and is not covered under warranty. The Fords are the same way. That's why I'll be doing the Dynatrac conversion the first time one fails.
Old Aug 8, 2006 | 12:20 AM
1320's Avatar
i m in the middle of a right front unit bearing failure.....my parts are to be delivered thursday from emsoffroad.com it a lock out hub version like the dynatrac but at about half the price and cheaper then doing both sides with oem parts.
Old Aug 8, 2006 | 04:13 PM
04.5RAMHD's Avatar
I just done the Dynatrac conversion as a PREVENTATIVE maintenance service
and because I despise the full time operation and its wimpy design so I have
a couple of good unit bearings with 28k miles if anyone is interested in some for cheap.
Old Aug 8, 2006 | 07:25 PM
Okie's Avatar
Red face
Thanks All
Truck back home with new bearing and fresh brake job. Total for all $850.00. Not the dealer. Just in case you have it done. Luckly the ABS senor ring in on the hub assembly and came with the new part.
Okie
Old Aug 9, 2006 | 12:27 PM
04.5RAMHD's Avatar
I don't think they have their kit available for the 3g trucks yet although
it is due out soon. Are all of the components U.S. made or are they using
imported pieces ?
Old Aug 9, 2006 | 12:32 PM
04.5RAMHD's Avatar
Here are some pics of the conversion.
Old Aug 9, 2006 | 05:01 PM
njmaier's Avatar
imported pieces ?
I have spoken to Eric at EMS...he hopes to have his 3rd Gen kits ready in a month or so...and his price point is projected to be much nicer than Dynatrac's. I'm not sure about the origin of the parts, but I know some of them he has to make. I believe that he said he was going to use Warn hubs, but I'm not positive of that. I'm kinda on his waiting list...i.e....my truck is broken and I'm waiting for him to get something together so I can try it out.
Old Aug 9, 2006 | 05:15 PM
ptgarcia's Avatar
He has to use Warn Premium hubs or nobody will by them. Nobody else out there makes anything worth buying (except maybe Milemarker).
Old Dec 25, 2006 | 12:39 AM
brickenbone's Avatar
yuo still have them?
K9I449
Jun 6, 2012 03:44 PM
Wilbur01
Aug 3, 2009 11:16 PM
skidooer76
Jul 18, 2008 09:07 PM
Bookshelf
Feb 29, 2008 09:11 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
