front wheel bearing 01 4x4
Old Jul 16, 2008 | 01:41 PM
skidooer76's Avatar
looking for the front wheel bearings for my 01' 2500 4x4, does anyone have a good source or part#
Old Jul 16, 2008 | 05:42 PM
high bid's Avatar
If you find it's the same part# as for a 99 4x4, I'll give you my used one (in good working condition)...just pay for shipping. I replaced it thinking it was bad but it actually ended up being the control arm bushings.
Old Jul 16, 2008 | 09:14 PM
j-fox's Avatar
you will be buying the entire hub. I think mine were $235, but not sure.
They will be very hard to pull out of the spindle! I had to cut the ball joints and have them pressed out. It was several tons.
I then cleaned up the casting and used anti-seize.
Old Jul 17, 2008 | 07:53 AM
high bid's Avatar
Mine came apart farily easy.......... after using an extremely large hammer. Overall, it just depends on how rusted toghether it all is. I think I bought mine from NAPA...about $150. Like I said, you're welcome to have mine if you find it's the same part#. Driverside sealed 4x4 hub assembly, just pay for shipping.
Old Jul 17, 2008 | 12:33 PM
j-fox's Avatar
I was told the 01's and 02's were fitted alot tighter.
And I think the part numbers are different for 99 and 2000.
Old Jul 18, 2008 | 09:07 PM
rebal's Avatar
same part use a socket on the bolt after loosening them up and turn the steering wheel as a press on the bolts it will pop out . theres a good write up that will walk you though it do a search in the 2nd gen section
K9I449
Jun 6, 2012 03:44 PM
Wilbur01
Aug 3, 2009 11:16 PM
Bookshelf
Feb 29, 2008 09:11 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
Okie
14
Dec 25, 2006 12:39 AM
