$4500 For Injectors!
Old Aug 13, 2008 | 07:28 PM
masonic-dodge's Avatar
Keegan
You always seem to say things better then me. I wish I could word things like my HERO (you).
Old Aug 13, 2008 | 07:40 PM
Mocho's Avatar
First mistake was going to the dealership when the trucks off warranty for work They charge ATLEAST double for CRAP parts. Here's a set for $640, don't have these and not sure how they are, but i'm sure they are miles better then the ones the dealer will put in, and for a faction of the price.
http://www.glacierdieselpower.com/pr...x?pf_id=E37006
w.tx iceman's Avatar
http://www.mwfi.com/_template/templa...tors&PageID=CR new injectors exchange
Old Aug 13, 2008 | 08:21 PM
Spooler's Avatar
All i have to say is Flux 1's. They will cost you 1200 for tips and 100 a piece to rebuild yours. Enough said.
Old Aug 14, 2008 | 07:53 AM
GOT BOOST?'s Avatar
Dude, brand spanking new injectors that have never seen diesel fuel can be had for 450-500 a piece, that dealer is a JOKE, like most of them are. I can always count on a good "dealer" story to further instill my faith in them. Jay
Old Aug 14, 2008 | 01:28 PM
Hintz's Avatar
I just check piers Brand New injectors for 380 bucks
Old Aug 14, 2008 | 02:30 PM
CrashCade's Avatar
Here is instructions with a list of tools to use to Remove and Install injectors. It is pretty straight forward and pretty simple to do in a couple hours. It is looks more daunbting than it really is.
http://www.dynomitediesel.com/user_p...html?page=Tech
Jason
Old Aug 14, 2008 | 02:53 PM
ian515's Avatar
X2...6 months ago I went through all this, even had the same thread goin too
F1 diesel, flux 1's and do it yourself. you can do it man!
Old Aug 14, 2008 | 03:57 PM
GOT BOOST?'s Avatar
That sounds about right, your truck is an 03, those are a little cheaper than 04.5 and up. Make sure once you get everything fixed you call up the dealer and tell them, it will give you some satisfaction. Jay
Old Aug 15, 2008 | 01:10 PM
lniemeyer2's Avatar
Tre
Another vote for Tim at TRE. He hooked a buddy of mine up and I know that's what I will be doing in the future. Here's his link http://www.trediesel.com/
Old Aug 15, 2008 | 06:43 PM
El Borrego's Avatar
I've replaced 3 injectors on my 03 and they cost $385 each, rebuilt. I found out something the other day to think about when shops say your injectors are bad. Do a double check on the Cam sensor. It it's having some trouble it can make your injectors act up making it seem as if the injectors are bad while the culprit is the cam sensor.
Old Aug 15, 2008 | 09:04 PM
Spooler's Avatar
Or the shorted wire that gives power to the cam sensor. See above sticky noted thread. A wire will short on the A/C lines above the compressor causing issues. Read the thread.
KRB
May 20, 2007 06:20 PM
v8440
Apr 10, 2006 04:05 PM
BIGOKIE
Jul 21, 2004 05:53 PM
RamThatStroker
May 29, 2003 07:38 PM
Superduty12v
22
Oct 11, 2002 07:42 PM
