$4500 For Injectors!
Old Aug 13, 2008 | 04:47 PM
Tedonlin150's Avatar
So I took the truck to the dealer this morning cause it was hard starting when warm. This afternoon they said it needs all new injectors due to dirt contamination over time. They want $4500 dollars for rebuilt ones. Is there another way to solve this problem such as having a shop rebuild them for less money or something. I am not very happy about this since a couple of weeks ago I brought it in for this problem and they put the in-tank lift pump update in for a lot of money. Im also considering trading it in since the dealer has trucks marked down so cheap. Any advice would be greatly appreciated. Thanks, Ted
Old Aug 13, 2008 | 04:51 PM
drolex's Avatar
Have you thought about just getting new injectors? Or buy some used injectors for even less money from someone who upgraded to different injectors.
Old Aug 13, 2008 | 04:56 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I bet the dealer is trying to make a 400% profit....$4500 are they nuts..There must be aftermarket performance injectors for these trucks for way less.I'm a 12V guy but doesn't 2001 injectors the same as 2003?Because the guys here have 2001 and a high end injector is no $4500....I would not take your truck to this dealer again.....$4500 for injectors give me a break......Ok I'm off the rant....
Old Aug 13, 2008 | 04:58 PM
DaveB.inVa's Avatar
I've always had in my mind that if I have an injector failure I'm going straight to aftermarket injectors. Cheaper, better reliability, more power. Whats to hate about that!
Old Aug 13, 2008 | 05:05 PM
UnrulyNFS's Avatar
Send them to Don at F1 Diesel, have him check them and upgrade them to 40hp injectors. Better spray pattern, more durable. Then get some good filtration on that thing like the GDP 2micron kit to keep crap in the fuel from making it to the injectors in the first place.
That's what I would do.
I could do a turbo, injectors, gauges, intake, studs and fuel system for that much.
Old Aug 13, 2008 | 05:06 PM
tool's Avatar
2001 and 2003 don't use the same injector at all.
A 2003 is a common rail engine where a 2001 is a electronicaly controlled mechanical injection rotary pump. (VP44)
Not the same animal, injectors for the CR engines are very expensive but I don't know what a good price is.
I'm sure someone who had to replace them ill chime in.
Old Aug 13, 2008 | 05:12 PM
phabib's Avatar
I think $900 each is the going rate for new injectors. I replaced a bad injector on mine for about $300. I think it came rebuilt from the Cummins dealer instead of new from Dodge.
Old Aug 13, 2008 | 05:17 PM
masonic-dodge's Avatar
Make sure that if you buy some injectors, they are 03-04s 04.5 and newer have a different spray pattern. A 03-04 injector will have 018 on the top and the04.5+up have 032 on the top.
CRIS
Old Aug 13, 2008 | 05:19 PM
Ok so i think that i will send them to F1 diesel. How do I go about doing that. Is it very difficult to take out the injectors or should i bring it to a performance shop to take them out
Old Aug 13, 2008 | 05:23 PM
Hintz's Avatar
Industrial Injection sells new injectors for 350 or 450 each
Old Aug 13, 2008 | 05:28 PM
Tim at TRE can make it happen 1-757-831-7451
Tell tim that Cris told you to call him about injectors.
CRIS
Old Aug 13, 2008 | 05:35 PM
annabelle's Avatar
I have the exact same situation. Dealer quote me $3600.00. I'm getting after market for much less.
Old Aug 13, 2008 | 06:02 PM
chipmonk's Avatar
amazing how fast the dealer finds bad injectors after truck is out of warranty.
Old Aug 13, 2008 | 06:19 PM
drolex's Avatar
Here you go: http://cgi.ebay.com/ebaymotors/6-Mop...spagenameZWDVW
$283 per injector
Old Aug 13, 2008 | 06:34 PM
UnrulyNFS's Avatar
You could take it to a performance shop, but thats more money. If your mechanically inclined, find someone experienced to help you or get a service manual. It's not too difficult, just time consuming. Just keep them clean and don't let anything touch the tips. When you put them back in, don't overtighten the injector harness nuts or they'll snap off. Snug is all you need.
Tim at TRE can definately hook you up. He's a sponsor on this site so look for his banner up top.
I certainly wouldn't pay for a new injector when you can have a working injector upgraded for better performance, spray pattern, and very often better fuel mileage.
