water in fuel
Old Dec 20, 2005 | 06:57 PM
fuel4me's Avatar
water in fuel
today i washed my truck and after i dried her, i got in to move it and it said water in fuel, so i drove it down the road and after prolly ten seconds it was gone, haven't seen it scince.
Old Dec 20, 2005 | 07:06 PM
infidel's Avatar
Very common, water got in the connector to the WIF sensor.
Either live with it till it drys or goop the connector up with dielectric grease to waterproof it.
Old Dec 20, 2005 | 07:15 PM
fuel4me's Avatar
thanks, i just wanted to make sure nothing major to worry bout.
Old Dec 21, 2005 | 04:17 PM
jrs_dodge_diesel's Avatar
If you ever pressure wash your engine compartment, Be sure not to hit this side to the fuel water seperator much.
Old Dec 21, 2005 | 06:04 PM
Clunk's Avatar
Thumbs up
Good picture JR.
Old Dec 21, 2005 | 07:41 PM
bentwings's Avatar
Hey my fuel filter canister doesn't have the heater!!! I want one.... What year do those come on and can I retrofit it???
99 3500 dually 5 spd
Old Dec 22, 2005 | 12:07 AM
That canister is the 2000 an up version. 98 and 99 had the older style all metal canister with the two test ports on the top. I am unsure if it would retrofit back to a 98 or 99. Even though you have the older canister, you still have a fuel heater, its just in a different spot. Most likely at the inlet to the fuel canister as that is how the newer style is setup.
In this next picture you can see the heater. It is the black ring at the top of the canister. Fuel comes into the canister and goes through the heater ring BEFORE going to the filter.
Old Dec 22, 2005 | 08:42 AM
Mopar1973man's Avatar
Hey JR...
Did you pull your filter housing for the post or was there another reason why you had you filter housing off?? I'm Curious...
Old Dec 22, 2005 | 08:43 PM
Originally Posted by Mopar1973man
Hey JR...
No not for the post. I was replacing the lift pump. I got really good access to it by removing the filter canister. I was replacing all of the banjos with Hi flows anyway so 2 banjos, 2 10mm bolts and 2 electrical connections and it was out. Fairly easy project over all.
Old Dec 24, 2005 | 08:02 AM
fuel4me's Avatar
thats awesome, thanks for the info
ZPOD
18
Sep 23, 2010 10:37 AM
DodgerDoob
Oct 1, 2008 07:49 AM
nooska
Jun 19, 2008 08:30 AM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
