help with 95 underdash wiring
I am in the process of installing my pyro and am looking for a keyed 12v source. In the process of looking I removed the lower plastic dash panel and found in about the middle of the dash kinda below the radio a grey plastic 14 wire 2 row plug with female round ports. I was thinking it looked like a stereo plug but the stock radio is still in it. upon probing it for 12v when I stuck one of the holes my ABS light on the dash came on.I stopped there. Several others are hot keyed or unkeyed and some ace mechanic cut about 6 of them for some reason. does anyone know if this is a test plug of some sort for dash instruments or??
Thanks all.
Scott.
Thanks all.
Scott.
Hey Scott.
Do you use the cigar lighter? I took the fuse out of mine and plugged into the cigar lighter fuse port for power. It's quick, easy and the power source is right there if I hve any problems. The 12v power port still works.
As I mentioned someone hacked thru several wires. One of which was a keyed 12V and I tapped into it for the pyro power, the rest I neatly insulated so they wouldent short out on something. Bad idea?? It sounds like it. Stupid thing to say but I dont even know if my truck has ABS.what posses the humanoid to be so desrtuctive when it comes to hard to get to wiring
treedweller
Feb 15, 2009 03:40 PM
charcoal600
Apr 30, 2005 02:34 PM
