Quick way to change heatrer core(2-3hours)
Old Dec 31, 2012 | 10:22 AM
  #106
robert78.5's Avatar
I followed the pictures and changed the core in no time at all. I removed fitting in the engine head to see if it was plugged. I found that the hole was only about 1/4 inch at the bottom of fitting. I drilled out to size of the end of fitting, this should help with the water flow i think. Lots of heat now.
Old Jan 1, 2013 | 09:07 PM
  #107
robert78.5's Avatar
I was told today that the fitting has a small hole to allow for engine warm up. I guess i will find out when i start it when cold.
Old Mar 2, 2013 | 06:24 PM
  #108
jaypry's Avatar
i need to replace my heater core. I was wondering before i start, do you have to remove any of the plastic around the gear shifter, I have a 2001 with the 6 speed manual. is there another instructional for a stick.
thanks
Joe
Old Mar 2, 2013 | 09:23 PM
  #109
Clunk's Avatar
It seems I had to remove the plastic from around the shifter to access the 2 bolts that connect the lower dash to the shifter plastic. Seems the boot has to be disconnected and placed up the shifter handle to access the plastic piece screws.
All help gratefully accepted.
Old Mar 2, 2013 | 10:18 PM
  #110
Mechanos's Avatar
Had to replace my heater core today... it was peeing flourescent green juice onto the floorboard. I did the cut & splice method. The Dodge dealer quoted me $1000 to replace the core and couldn't get to it until next Wednesday. I was able to do it in an afternoon for $71. The wiring and such to the gauges on my pillar pod were an added effort. I could not lay the dash back without removing the gauge pod. All in all, it took me about 5 hours.
Now, I'm still trying to remove the nasty anti-freeze film all over the inside of the windshield. I was using the defroster when the heater core blew and it fogged the entire inside of the windshield with anti-freeze.
Old Mar 3, 2013 | 08:50 AM
  #111
Clunk's Avatar
While on problems, what do you do to remove the antifreeze smell from the heater box & duct work?
Old Mar 3, 2013 | 09:20 AM
  #112
Mechanos's Avatar
If you take the heater box all the way out, you could wash it out. When leaving the box in, I stuck the shop-vac hose down into the box where the core sits and sucked out what I could. The rest of it? Time. I wadded up a frabic sheet and stuck into one of the floor heat duct openings, so at least it smells a little better in the cab. Who knows... maybe it will take the wrinkles out of my seats too.
Old Mar 9, 2013 | 01:38 PM
  #113
cLAYH's Avatar
My dad has this truck now. 4 years later and still no leaks and have never had to retighten it.
Old Mar 9, 2013 | 05:24 PM
  #114
Clunk's Avatar
Thanks for posting this shortcut cLAYH !!!!!
It saved me a bunch of time and trouble
Old Apr 30, 2013 | 07:16 PM
  #115
mtdoragary's Avatar
Originally Posted by jumper
I'd double clamp it. I blew a single clamped non-swedged radiator pipe on my mustang at Thunder Hill. It's been fine since with two clamps on each end.
On this same mustang we just replaced the heater core. I took the old one to a radiator shop and they reused the copper end tanks, silver soldered the pipes to the tank, re-cored it with a proper copper core and we're good as new. The thin cheesy $20 aluminum heater cores have very thin joints where the pipes intersect the tank and I just didn't trust them. The re-core was $85.
I agree with the re-core of a brass and copper tank. I also agree with double clamping - it's the standard in marine use. I also agree with thinking outside the box. I wouldn't be on this site if I didn't. And I wouldn't have had some of the most fun vehicles of my life - 327-375hp fuelie in an MG-TF, Corvair 140 in a Porsche Roadster, blown hemi in a Glen L an Porsche Super 90 in a 13 foot Checkmate... oh yeah, and an 11 second Excelsior Henderson and a Triumph powered Whizzer....
Old Jan 30, 2014 | 11:16 AM
  #116
Clunk's Avatar
What, no vids of the 11 second Excelsior Henderson or the Triumph powered Whizzer...???
Not fair!
Old Jan 30, 2014 | 07:20 PM
  #117
mtdoragary's Avatar
Not fair!
You're telling ME! To my great regret, I wasn't taking pictures before the era of the cellphone. I have NO pictures of the Whizzer or of my Fuelie Vette powered 55 MG-TF, and I can't find any friends or family that have any either.
But I believe the EH is on the page I have all of my latest motorcycles on. http://www.labradoodlepuppy.net/home
Old Feb 2, 2014 | 12:16 PM
  #118
cLAYH's Avatar
Originally Posted by dieselman2300
Same ones I get. Good old made in the USA stainless steel clamps.
Its probably more like the HD heater hose I used.
I dont care what anyone here says, personally I would take the extra hour and do it right the first time. I would hate to spend 2-3 hours AGAIN tearing the dash apart, having to but ANOTHER heater core, for an extra hour worth of work.
I'm with JLent on this one, if it isnt flared on the ends your looking for trouble.
I guess only time will tell.
Looks like time has told. 5years later, still no leaks, evap is still fine. Never had to re-tighten clamps.
Old Feb 27, 2014 | 08:16 PM
  #119
Ron E's Avatar
I'm 2 years in. No re tightening and no leaks to date. I think this method is plain old good advice.
Old Feb 27, 2014 | 11:10 PM
  #120
ldornak's Avatar
I'm only 1 month in but I agreee
