Quick way to change heatrer core(2-3hours)
Old Mar 27, 2014 | 08:25 PM
  #121
Clunk's Avatar
3+ years for me....thanks again cLAYH
The antifreeze smell finally left.
If I have to replace it again, I'll spray some windex down there then vacuum and wipe it out with paper towels and see how that works.
Old Mar 28, 2014 | 01:04 PM
  #122
cLAYH's Avatar
The biggest bonus to this method is that you don't have to drain the AC system which isn't an option for most DIYers. At least not properly.
Old Nov 7, 2014 | 06:37 PM
  #123
NMassey's Avatar
Did you all unhook any wiring harnesses or anything? Or just undo the bolts and pull the dash back? Getting ready to change my heater core tomorrow
Old Nov 7, 2014 | 10:18 PM
  #124
cLAYH's Avatar
Its been a long time but I don't think I had to undo any thing other than maybe the wiring for the heater box.
Old Nov 8, 2014 | 09:17 AM
  #125
Clunk's Avatar
I didn't disconnect any wiring.
Thanks again cLAYH!!!
Old Nov 8, 2014 | 10:09 AM
  #126
cougar's Avatar
I used a core with the rotating tubes. Was able to get it in by just loosening the box and moving it back a little.
Old Nov 8, 2014 | 10:57 PM
  #127
cLAYH's Avatar
Where did you get it? I wasn't able to find one locally.
Old Nov 9, 2014 | 10:34 AM
  #128
cougar's Avatar
Through Amazon. All they had locally where non rotating and very expensive.
Old Nov 11, 2014 | 08:10 AM
  #129
ramguypa's Avatar
Is this possible on the 3G rams? I need to put in a new core and was thinking I could possibly cut the box and the do what you guys did and cut out the old core and splice in the new one. I'm ok with cutting the box and just taping the plastic back together. Let me know if you guys think something like this would work. Thanks
Old Nov 13, 2014 | 11:33 AM
  #130
NMassey's Avatar
Hey guys, I forgot to comment back, this was a life saver, had the heater core out and replaced in a hour and a half! Thank you for this!
Old Nov 15, 2014 | 04:10 PM
  #131
volman's Avatar
I joined the club today. Knocked it out in just over 2 hours, and it worked like a charm.
Old Nov 15, 2014 | 05:36 PM
  #132
Clunk's Avatar
Welcome to the club
Old Nov 15, 2014 | 06:03 PM
  #133
volman's Avatar
Thanks! I actually found this message board searching for info on replacing the heater core. It worked so well, I joined.
Old Mar 15, 2015 | 08:28 PM
  #134
Jaquez4's Avatar
Hey guys new to the forum. I attempted to replace my heater core today but was unable to get the dash out. I think I'm missing something since it feels it is catching somewhere near the steering column. I lowered the steering wheel (removed 4 nuts) letting it go to the floor. Seen where people only remove two. Not sure if I over did it there. Removed the 3 bolts on both driver and passenger side, 2 bolts on center console near floor, 4 screws on top of dash, and the 2 bolts on top of dash last. I could fairly easily move the passenger side a couple of inches but when trying to lift or pull the drives side it felt as it where still connected somewhere. Can someone point out what I'm missing? Thanks for the help.
Old Mar 16, 2015 | 08:04 PM
  #135
Clunk's Avatar
Try lifting that end of the dash an inch or so before pulling it toward the rear.
