Oil pressure gauge
Oil pressure gauge
2oo1 oil pressure gauge is stuck at 40psi with key on or engine running. Unplug sending unit and gauge reads Zero. Self-diag on cluster is good. Suspect oil sender but at $180. want to be sure first. Any help?
Location: Dayton, NJ (temporarily while In USCG on Staten Island)
Just put in a -5 aeroquip hose to the plug in the oil filter housing . The plug in on top towards engine. A mechanical gauge and hose will be about $50.00. If you need a line made I can make it and mail it to you, just measure what you want.
Stephen
Stephen
$50!!!!!!!
More like $15, all you need is a grease gun hose, a 1/8" pipe coupling (or bell reducer depending on the size thread on the gauge) and a $7 100 psi pressure gauge.
The grease gun hose is the same thread as the port on top of the oil filter housing.
Just screw the hose in with the gauge at the other end.
If you need a new sender buy it from Cummins for half the dealer's price.
Avoid autoparts generic senders, they don't last.
Thanks for the info. I suspected the sending unit and tested the oil # with a gauge at the filter port and all is good. At $180 for a sending unit i may just leave it at showing 40 lbs for a while. When you said buy from Cummins is it a dealer or can you do it on-line
Click for dealer locator> http://www.cummins.com/service_locator/index.cfm
GlennRMK
05-24-2007 10:46 PM
Matt Lambrech
01-28-2007 04:13 PM
Ripper01
04-11-2006 09:10 PM
streetsmoker
02-22-2006 06:47 PM
