No brake fluid in system
Old Oct 4, 2004 | 07:27 AM
DZLPWR's Avatar
Angry No brake fluid in system
I had a brake line go bad just above the load sensor valve, rusted up and got a pin hole. All the fluid dranined out of the system.
Anything special i should do when re-filling besides bleeding real well? I think im going to pick up a vaccum bleeder to help. What a great way to start a moday. Thanks -Jake
Old Oct 4, 2004 | 08:16 AM
Geico266's Avatar
Don't use the vacuum bleeder too much. (too much vacuum) you can suck air and crud from around the cylinders causing more problems. Been there, done that. In fact I would recommend you NOT you a vacuum system.
Old Oct 4, 2004 | 04:37 PM
MnTom's Avatar
I think the best way is to go rent a power bleeder. That way you will push the fluid through. I tried using a vacuum pump and I don't know if it was too much or what, but I had to bleed the rear brakes "the old fashioned way" to get any kind of pedal back.
Tom
Old Oct 4, 2004 | 06:47 PM
DZLPWR's Avatar
I assume that a power bleeder "pushes" the fluid through the system? Ive bled them the old fashsioned way before. Just wanted to try something easier and try not to mess up the master cyl. by pushing the pedal too far like infidel says.
Old Oct 4, 2004 | 06:52 PM
infidel's Avatar
I've never had a problem with a vacuum bleeders, use them all the time, don't see how it could suck air and crud from around the cylinders when the only opening is the reservoir. Now maybe if you opened all your bleeders at once then sucked at just one you could run into trouble, but why do that?
Old Oct 4, 2004 | 08:18 PM
Geico266's Avatar
All I know is I used the vacuum bleeder and pulled air into the system. All I was doing was changing fluid. I had not opened the system. I had to gravity bleed the brakes to get the air out.
Old Oct 4, 2004 | 08:38 PM
MnTom's Avatar
When I did mine, I used a 4cfm vacuum pump. Did a 4 wheels and got in the truck and the pedal was on the floor and wouldn't even pump up. I had my son (who kept the MC full entire time) pump the pedal and I re-bled the rears and VIOLA!!! had better brakes than I have ever had. I don't know how the rears got air in, but they did.
Tom
Old Oct 4, 2004 | 09:52 PM
wgingg's Avatar
powewr bleeders are the fastest and easiest way to go. a little air pressure and a full tank of fluid, crack this bleeder then that one and your done
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
mr T
Oct 16, 2005 07:38 PM
ddestruel
Apr 6, 2005 11:26 AM
