Newbie - Help identifying an unknown add-on
I just picked up my truck (specs below) this weekend and have a question about, what looks like an after market addon.
Mounted to the dash are 1) a vacuum gauge and 2) a pull handle. When the handle is pulled the vacuum reading changes. Other than that I see (or feel) no effect. The tubing and cable are routed to a unit on the drivers side of the engine compartment. There it a steel tube running from it to the brake master cylinder.
Can someone tell me what this is?
2002 Dodge 3500 Quad Cab Dually
5.9L HO Diesel
M6 trans
4x4
5.9L HO Diesel
M6 trans
4x4
Originally Posted by Sidewinder
Only guessing but could it be a manual 4X4 engagement or 2 wheel drive LOW selector?
Does it put the truck into 4X4?
No to the going into 4x4. I thought it may be some sort of vacuum/manual parking brake but it doesn't hold the truck.
If you put the truck into 4x4 normally and then activate the switch, can you tell a difference? (Lots of people make a 2WD low kit that lets them disconnect the front axle while in 4x4 mode, makes it easier to turn/manuever when backing a heavy trailer).
~Rob
~Rob
Found it: trailer brakes. I crawled underneth this weekend and found hoses running to the bed. I removed the bed liner to find a connection panel used to tow a gooseneck trailer. I know this because I also found a drop down gooseneck hitch in the bed. Oh the things a bedline can hide.
Hooligan6
22
Jul 17, 2007 11:41 PM
chw
Jul 16, 2007 10:39 AM
dodgemaniac
Jun 12, 2007 08:21 AM
