Lowering rear of a 2wd 3/4 ton Quad cab...
Old Mar 21, 2007 | 10:19 AM
4RnrRick's Avatar
Does someone make a nice kit to lower the rear of a 3/4 ton quad cab 2wd? I'm thinking 2-3" would be nice, but the overload bumpers would also need to be relocated up. Just curious if you guys know of a 'complete' kit to keep the factory ride quality and load capacity.
I've seen leveling kits, but they raise the front and I don't want to do that. (My wife has hip problems so she needs a low step in height.)
Old Mar 21, 2007 | 10:49 PM
4RnrRick's Avatar
Andybody have any links?
Old Mar 21, 2007 | 10:56 PM
ScottN's Avatar
You would probably need to get skinnier overload bumpers or just cut them. I would talk to a spring shop - parts to lower trucks aren't nearly as popular as parts to jack them higher.
Old Sep 23, 2008 | 02:09 PM
woopow's Avatar
Lowering kit to flip springs on an 'O6 3/4 ton.
I just found these today. It looks like they just came out on the 19th of this month.
http://truckn.com/Tech-Instructions/...ON/FLIPKIT.pdf
I plan to do a little more research, but I may me buying some of these. I have a Kelderman Air Ride system on my '06 and it sits too high in the rear with the recommended air pressure. This lowering kit with the proper amount of air should drop my truck about 2" below stock. Just thought I would share what I found.
Old Sep 24, 2008 | 08:22 PM
juicedbusa02's Avatar
heres the kit I have on the rear of my 98.5 shortbed
http://www.stylintrucks.com/parts.aspx?partid=19451
it has 2 settings so you can go either 3 or 4" of drop I did the 4" drop because i cut a coil out of the front springs as well.. ride is not compromised and install wasn't too bad but i would reccomend taking the bed off.. much easier..
heres a couple pics of my shorty so you can see about how low it would be
good luck!!!
Chris
nasty01cummims
Jun 30, 2009 01:52 PM
Mike4122KSA
Nov 8, 2006 08:46 PM
narlinghaus
16
Nov 2, 2006 10:25 AM
flathead
Jan 30, 2005 08:10 PM
ppsi
32
May 15, 2004 02:19 PM
