lowering rear of 2004 3500 2WD
Old Jan 2, 2004 | 11:12 AM
ppsi's Avatar
Question lowering rear of 2004 3500 2WD
I just got my new truck home and would like to lower the rear. I see there are two "spacers between the axle and first leaf. Is it OK to ditch these? Any other free lowering ideas?
Old Jan 2, 2004 | 08:39 PM
Grey Rider's Avatar
There should not be a problem removing those spacers.
Old Jan 2, 2004 | 10:42 PM
PROSOUTH's Avatar
From: Dead Center in the Middle of TN. 20 miles from Jack Daniels, 10 miles from George Dickle and .8 mi from the liquor store at I-24 Exit 114
I have looked at this also and the two spacers aren't hardly enough, any other ideas on how to lower it about 2 inches? Jim
Old Jan 3, 2004 | 09:24 AM
PROSOUTH's Avatar
I think the parts you are reffering to are made for the 1500. The 3500 has welded on spring hangers and Dodge used the hydraformed frame rails and does not reccomend grinding , drilling or welding on this frame.
The shackle kit I have not found listed for a 3500 yet either. Let me know if you come up with a viable 2" rear drop that will work with it. Thanks jim
Old Jan 3, 2004 | 05:56 PM
PROSOUTH's Avatar
Sorry I am wrong totally on the hangers, sorry mine are welded too..De-arch the springs
I checked the web site and it showed a set of shackles to lower a 3500 by 2" but that was only current to 2000.
I can only see taking out the two spacers we are speaking of. The shackles are so short now that I don't think they will be able to be shortend any at all.
Let me know how the De-arch comes out.........Jim
Old Jan 3, 2004 | 06:05 PM
Grey Rider's Avatar
Prosouth,
How the heck are you going to LOWER the truck and still fit 315s on? They barely fit with the suspension at stock height!
Old Jan 3, 2004 | 07:21 PM
PROSOUTH's Avatar
Prosouth,
STEP BACK FROM THE COMPUTER AND TAKE A DEEP BREATH!
Grey Rider I think yo have become confused from multiple posters and not a good profile available of each.
I have a 2WD QCSB 3500 with the fatory Michelins on it. It sits low in the front at about 4' over the tire and 8" over in the rear. Two inches is all I want to drop it in the rear and it will still be 6" over the tire.
Funny ain't it, I got a Jeep Cherokee that's lifted and the 1 ton I want to lower it.
Jim
Old Jan 3, 2004 | 09:25 PM
Raspy's Avatar
ppsi,
I took out the two lowering blocks on my truck and am glad I did. The truck is almost level and looks a bit better. It's not to hard to do.
Also, if you wanted another bit you could remove the overload leaf under the spring pack (on the 2500's), this is almost an inch thick, but it would reduce your load capacity.
All you have to do is pull a rear wheel while supporting that side of the truck with a jackstand under the spring pack behind the axle. Support the center of the axle (in the middle of the truck) with a floor jack. Put a "C" clamp on the spring pack in front of the axle. Remove the U bolts. Lower the axle with the floor jack about 4 inches. Remove the spring center bolts one at a time and replace with 3 1/2" grade 8 bolts and nuts (loosen both bolts, swing the lifting blocks asside and install the first bolt with Locktight Blue, also grip the round bolt head with a vice grip to remove the nut). Move the plastic centering pin to the overload leaf and jack the axle back up with the floor jack. Use a deep socket to re-install the U bolts. Re-install the wheel and go to the other side.
The new bolts are hex and the existing are small round head, so I was aware of the flat orientation as I tightened them to allow maximum clearance in the axle saddle.
It's quite easy and you could always go back if you wanted.
Wetspirit
Old Jan 4, 2004 | 11:48 AM
Grey Rider's Avatar
Prosouth,
I just find it amazing that 315s will fit a lowered truck, when so many have reported rubbing with the suspension at stock height.
Or am I way off, and 2wd trucks are not susceptible to rubbing as 4wd trucks are?
Old Jan 4, 2004 | 01:26 PM
Raspy's Avatar
Gary,
Smooth as glass, before and after. Mine is a standard cab and I think the vibes are on the quad. Is that right? The driveline angle has not changed compared to having a few hundred pounds in the bed, or however much it would take to lower it about 1 1/4" at the axle before removing the blocks. No problem. Headlights point up more though, I'll look at that today.
Grey,
I'm only talking about lowering the back to, almost, level the truck. I don't think there has been an issue with the clearance on the rear and larger tires, within reason. The wheel cannot go farther up into the wheelwell when lowered as the stop still hits the axle the same as before, we're just giving up a little of the normal travel. Next is H2 wheels.
Wetspirit
