High Beam + Low Beam
Trying to keep my low beams on all the time. I cross wired the violet/white wire to the light green ( more like a yellowish green). It works except when I release the HB/LB lever there is a loss of intensity. And the lights are not all that bright anyway.
That's what I did. And it worked fine for at least a year then the other day I noticed when I released the HB/LB leaver ( after flicking on the high beam) there was a loss of intensity.
get a relayed harness from lmc truck or daniel stern. once this is installed you will have an unused factory headlight socket - then just jump the high and low pins with a one way diode. this is the safest and easiest way as it is all plug and play - no tampering with factory wiring beyond the sockets themselves.
the relayed harness will also net you some light output improvement.
http://www.lmctruck.com/icatalog/de/t.aspx?Page=27
http://www.danielsternlighting.com/home.html
I use a $5 relay behind the driver's side headlight to trigger hi and lows at the same time.
The Dodge wiring is cheap, seems like they were trying to save 10¢ by using the minimum wire gauge and switch ratings they could get away with.
I'd be afraid of melting things down trying to force more juice though them.
just a word of caution for you if you are using aftermarket housings . . .
I made my own relay system before I did the Hi/Low splice, if anything it supply's more power to the bulb and i would think make it hotter. And as I said, it has been working for about three years now.
Floyd
Floyd
I tried the wiring harness (got a "look a -like" from Summit). It self destructed in about a year ( both the relays and the bulb holders). Could one of you all diagram a relay install. As I said the wires are crossed. But when I release the high/low beam lever the lights dim a little. If I hold it back towards me they stay bright.
As mentioned in post # 6 Try this site: http://www.danielsternlighting.com/t...ys/relays.html Good information and gives a relay diagram and good price for relay kit.
Floyd
Floyd
04ctd
18
Feb 15, 2018 08:25 PM
IPDiesel
Dec 16, 2010 04:25 PM
Steve034x4
Apr 24, 2008 06:33 PM
