Heated Mirrors
Old Jan 12, 2004 | 09:58 PM
mysterync's Avatar
Heated Mirrors
I have traded for a set of heated and power mirrors off a 99 3500 and im going to put them on my 95. I was wondering if my harness would plug up? or if ill have to straight wire it?
Thanks
luie
Old Jan 12, 2004 | 11:06 PM
magnum's Avatar
Did your 95 have power mirrors? If it didn't you are going to need wiring and switch from a newer truck. Check with your local salvage yard for some of those parts.
Old Jan 13, 2004 | 06:35 AM
mysterync's Avatar
Yes, It had power mirrors, I didnt know if the Heated &Power Mirror plugs were the same as just power.
Thanks
Lucas
Old Jan 13, 2004 | 07:09 AM
magnum's Avatar
I'm not sure either, there might be an extra wire, just inspect the plugs thoroughly and count the wires. That should give you an indication as to what is going on. I really don't know what to tell you except I do have a switch on my dash for the heated mirror part, so it might be logical to conclude that there is going to be more than simply plugging them in.
PS. My heated mirrors will only stay on for about 5-10 minutes b4 bugging out.
Old Jan 13, 2004 | 07:33 AM
mysterync's Avatar
Bob,
Thanks for all your help, i'll probably just cut the heated wires and plug them straight, i better find a schmatic to make sure theres not required relays! heated mirrors and melted mirrors tend to be some what diffrent, the melted ones done have as nice of apperance! Thanks again for all your help!
Old Jan 13, 2004 | 07:40 AM
magnum's Avatar
Definately a good idea to find some wiring diagram, should be able to find one of the guys who knows much more than I do. There HAS to be some relay in there, because otherwise, why would the mirror heat only stay on for so long??
It would have to be in the switch itself, or under the hood in the black box.
BTW: Post your truck on your signature so that everyone can know what you have....
Old Jan 13, 2004 | 07:51 AM
mysterync's Avatar
Bob, Thanks for being so kind, its just a sign there are nice people left........ lol maybe i need to get out of carolina to find them
Changed the sig. But forgot ive got banks pillar gauges with red lenses and red bulbs. Also all the lights on my truck except clearence lights are led. I know you prolly dont care, just making a note to self for stuff to change
thanks again
lucas
Old Jan 13, 2004 | 10:08 AM
infidel's Avatar
The heated mirror setups have a timer relay under the dash. Unless you have a good memory as to when to turn them off suggest you use one also.
ChicagoSnow
56
Jan 26, 2008 12:09 AM
GreenZ
Mar 1, 2005 03:40 PM
Scubasteve
Feb 6, 2004 07:21 AM
boughtadodge
Nov 1, 2003 09:22 AM
Bradtothebone
Apr 16, 2003 02:46 PM
