Electrical Shematic for heated mirrors?
Old Feb 2, 2004 | 07:54 PM
Scubasteve's Avatar
Both my mirrors dont heat up and I was wondering is someone could tell me what color wires do what on the back of the climate control.
I have not taken it apart yet as I was hoping to have an idea what is in that circuit I.E relay, temperature sensor etc.
Jason
Old Feb 3, 2004 | 07:57 AM
jfpointer's Avatar
Here you go, text and pictures from the '02 FSM:
DIAGNOSIS AND TESTING - HEATED MIRROR
SWITCH
The heated mirror switch, the solid state electronic
heated mirror system control logic and timer circuitry,
the heated mirror system indicator lamp and
the heated mirror relay are all integral to the a/c
heater control. For circuit descriptions and diagrams
(Refer to Appropriate Wiring Information).
WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS,
DISABLE THE AIRBAG SYSTEM BEFORE
ATTEMPTING ANY STEERING WHEEL, STEERING
COLUMN, OR INSTRUMENT PANEL COMPONENT
DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE
THE BATTERY NEGATIVE (GROUND) CABLE,
THEN WAIT TWO MINUTES FOR THE AIRBAG SYSTEM
CAPACITOR TO DISCHARGE BEFORE PERFORMING
FURTHER DIAGNOSIS OR SERVICE. THIS
IS THE ONLY SURE WAY TO DISABLE THE AIRBAG
SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS
COULD RESULT IN ACCIDENTAL AIRBAG
DEPLOYMENT AND POSSIBLE PERSONAL
INJURY.
(1) Check the fused ignition switch output (run/
start) fuse in the Junction Block (JB). If OK, go to
Step 2. If not OK, repair the shorted circuit or component
as required and replace the faulty fuse.
(2) Turn the ignition switch to the On position.
Check for battery voltage at the fused ignition switch
output (run/start) fuse in the JB. If OK, go to Step 3.
If not OK, repair the open circuit to the ignition
switch as required.
(3) Disconnect and isolate the battery negative
cable. Disconnect the 3-way instrument panel wire
harness connector for the heated mirror switch from
the heated mirror switch connector receptacle on the
back of the a/c heater control. Check for continuity
between the ground circuit cavity of the wire harness
connector and a good ground. There should be continuity.
If OK, go to Step 4. If not OK, repair the open
ground circuit to ground as required.
(4) Reconnect the battery negative cable. Turn the
ignition switch to the On position. Check for battery
voltage at the fused ignition switch output (run/start)
circuit cavity of the 3-way instrument panel wire
harness connector for the heated mirror switch. If
OK, go to Step 5. If not OK, repair the open fused
ignition switch output (run/start) circuit to the fuse
in the JB as required.
(5) Turn the ignition switch to the Off position.
Disconnect and isolate the battery negative cable.
Reconnect the 3-way instrument panel wire harness
connector for the heated mirror switch to the heated
mirror switch connector receptacle on the back of the
a/c heater control. Reconnect the battery negative
cable. Turn the ignition switch to the On position.
Depress and release the heated mirror switch. The
amber heated mirror system indicator lamp next to
the heated mirror switch button should light. If OK,
go to Step 6. If not OK, replace the faulty a/c heater
control.
(6) Back probe the fused heated mirror relay output
harness connector for the heated mirror switch on
the back of the a/c heater control and check for voltage
(battery voltage less the resistance in both outside
mirror heating grids). If OK, (Refer to 8 -
ELECTRICAL/HEATED MIRRORS/HEATED MIRROR
GRID - DIAGNOSIS AND TESTING).
GRID
For circuit descriptions and diagrams (Refer to
(1) Disconnect and isolate the battery negative
cable. Disconnect the door wire harness connector
from the power mirror wire harness connector at the
power mirror with the inoperative heating grid.
Check for continuity between the ground circuit cavity
in the door wire harness connector for the power
mirror and a good ground. If OK, go to Step 2. If not
OK, repair the open ground circuit to ground as
required.
(2) Reconnect the battery negative cable. Turn the
ignition switch to the On position. Turn on the
heated mirror system. Check for voltage (battery
voltage less the resistance in the outside mirror heating
grid that is still connected) at the fused heated
mirror relay output circuit cavity in the door wire
harness connector for the power mirror. If OK, go to
Step 3. If not OK, repair the open fused heated mirror
relay output circuit to the heater and air conditioner
control unit as required.
(3) Check the outside mirror heating grid by testing
for continuity between the ground circuit and the
fused heated mirror relay output circuit cavities in
the power mirror wire harness connector. There
should be continuity. If not OK, replace the faulty
power mirror. If OK, check the resistance through
the outside mirror heating grid. The correct resistance
should be from 10 to 16 ohms when measured
at an ambient temperature of 21° C (70° F). If not
OK, replace the faulty power mirror.
Old Feb 5, 2004 | 09:54 PM
Scubasteve's Avatar
That is very cool Jim
thank you very much for taking the time to post that for me.
Once I get everything in the house fixed from the power surges we had when the guy plowed into the hydro pole down the road I will have a look at it.
Thanks again
Jason
Old Feb 5, 2004 | 10:00 PM
Scubasteve's Avatar
Thanks again
Jason
Old Feb 6, 2004 | 07:21 AM
jfpointer's Avatar
Thanks again
Jason
You're welcome. Happy to help out. I have the pdf version of the manual, so it was mostly cut and paste other than just saving the picture off in a format and size the forum would take.
12valve
Jun 1, 2009 09:01 AM
ChicagoSnow
56
Jan 26, 2008 12:09 AM
mysterync
Jan 13, 2004 10:08 AM
boughtadodge
Nov 1, 2003 09:22 AM
Bradtothebone
Apr 16, 2003 02:46 PM
