Fuel sending unit replacement
Old Nov 18, 2004 | 10:35 AM
Lenn's Avatar
To replace sending unit by tipping bed do you have to relieve fuel pressure from the system? Do ypu need to buy a new locking nut for the module? If there is any other tricks I would appreciate any help.
Old Nov 18, 2004 | 10:37 AM
Mcmopar's Avatar
I did mine, no pressure to relieve, used same lock nut, and a large strap wrench.
Old Nov 18, 2004 | 06:42 PM
MNorby's Avatar
it was pretty easy with a nearly empty tank to take the 2 nuts off and lower the tank. The lines you push together, squeeze the little clips and pull apart. I used a straight screwdriver and hammer to loosen the big retainer nut. When going back together the new rubber gasket was kinda tricky to get all in and down but not really too bad.
Old Nov 18, 2004 | 06:49 PM
infidel's Avatar
Nearly empty tank is the key, hard part is getting it nearly empty without running out when the gauge doesn't work.
That's why I prefer tilting the bed.
If you dont have the means to tilt the bed use two racheting type nylon load straps to raise and lower the tank.
Old Nov 19, 2004 | 01:03 AM
Hemi Cat's Avatar
I think it is easier to tilt or lift the bed. If you use a hammer and screwdriver for the retainer collar ring, be carefull it's plastic. when old it gets brittle. Better to use strap or chain wrench if available. When complete, make sure the wire connector is locked in place, if it broke comming apart, use zip ties to secure in place. Good luck
Howard
Old Nov 19, 2004 | 08:00 PM
COLDHEART's Avatar
If you can get hold of a motorcycle jack and a couple of tie downs....works great even with fuel in it.
Old Nov 20, 2004 | 01:49 PM
argve's Avatar
Now that's using the ole noggin. I'll remember that when I do mine here in the spring (gonna wait for warmer weather). Mine does not work either but at least the warning light works to tell me I have 10 gallons of fuel left.
Old Nov 20, 2004 | 06:38 PM
Geico266's Avatar
If you find a little green ball in your tqank throw it out and you won't need to replace the sending unit. The geen ball is an anti rollover spilling device that Dodge came up with. Mine went into the tank and hung up the sending unit.
Southern Pride
May 18, 2010 07:47 AM
JasonblkZ06
May 16, 2009 08:02 PM
B.A.Ram
13
Sep 2, 2005 10:23 AM
dcwm
Jun 13, 2003 12:27 PM
figure_9_pro
Nov 11, 2002 08:53 PM
