Fuel gauge fluctuatuion
Old Jul 9, 2003 | 06:36 PM
RAMified's Avatar
Has anyone experienced a problem with a fuel guage reading all over the place? I'll run a full tank to 3/4 with no problem then a real quick drop from 3/4 to half. When guage is around 1/4 and I shut and restart, the fuel low light will come on and alarm will sound. I ran it down to 1/8 tank and when alarm sounded, shut down and restarted. After running at idle for a few minutes, the guage went up to around 5/8 tank. If I fill up at this time it will only take 16 to 17 gallons. What do think? Sending unit, guage, grounding? any ideas where to start? I do a lot of towing and it's driving me nuts not knowing how much fuel I really have. Thank's<br>
Old Jul 10, 2003 | 08:19 AM
BarryG's Avatar
Re:Fuel gauge fluctuatuion
My sending unit went out at 52k. Read 1/3 of tank and ran out of fuel in the middle of a busy intersection that was fun. Previous to that it had never shown a sign of being off or acting funny. I usually watch the mileage to the gauge but that particular time I didn't. Have since found out that it is a relatively common problem according to the dealer.
Old Jul 10, 2003 | 09:34 AM
JFellman's Avatar
Replaced my sender a couple weeks ago. The sender was real dirty but it wasn't worn out. After I cleaned it it worked perfectly according to the ohm meter...so I saved it for a spare.
Old Jul 10, 2003 | 09:36 AM
JFellman's Avatar
Here's a pic of the top of the tank
Old Jul 10, 2003 | 09:41 AM
royB's Avatar
although it was not on a dodge, had one that acted exactly like that, full to 3/4 was fine, after that you never knew.. it would jump around and one minute is would show empty the next 5/8 then 1/8 etc...<br><br>replaced the sender and problem went away
Old Jul 10, 2003 | 07:26 PM
firestorm's Avatar
Probably the sender, but put the truck computerinto 'self check' mode to pull a code. I listed the directions for self check below.<br><br>1: Hold the odometer/trip button in on the dash, and turn the ignition key to the &quot;on&quot; position. Then let go of the button.<br>2: Your odometer will read &quot;CHECK&quot;, and your gauges and lights will be acting weird, that's OK.<br>3: After everything goes back to normal, turn the key off.<br>4: Turn the key to the &quot;ON and &quot;OFF&quot; three times ending in the &quot;ON&quot; position. Your codes, if any will appear in the odometer.If there are no codes, and/or after the codes are displayed &quot;P-done&quot; will appear in the odometer. <br>If you missed any of the codes, repeat step 4.<br>5: Click on the link below to interpret the codes.<br><br>http://www.obdii.com/codes.html<br><br>Hope this helps
Old Jul 10, 2003 | 08:24 PM
Stamey's Avatar
My 99 did something like that the other day. First it went to full when I knew it had a half tank in it, then a couple more miles down the road it went to empty and the alarm started going off . Then a couple miles further it went back to normal and seems to be reading accurately, as it WAS pretty low tonight and I still drove it about 20 miles after the alarm and did not run out. :<br>I thought sender when it was stuck on full, as there is a TSB about that, but the empty things is a mystery, unless I have a bad electrical connection between the cab and the sender. <br><br>I will not actually try to track it down until it starts happening regularly.<br><br>Chris
Old Jul 10, 2003 | 08:53 PM
RAMified's Avatar
Thank's guys!!! I'm ordering the sending unit tomorrow. I did find something else in the forum archives about a repair kit available for about three bucks from Huey C. along with a full discription of the problem, cause and corrective action. Check it out.
nrussell
Jul 23, 2008 08:58 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
