Fender Replacement
Old Jun 17, 2010 | 08:02 PM
Captum's Avatar
Exclamation Fender Replacement
Good eveneing all.
It is now time for me to replace both fenders due to heavy rust.
Can anyone give me an idea on what to expect when taking things apart.
Old Jun 17, 2010 | 09:26 PM
Dr. Evil's Avatar
Mine have finally started to rust too. Watching this with interest.
Old Jun 18, 2010 | 05:01 AM
Captum's Avatar
I shall probably start in mid July. Once I start I will try to take some pics.
I obtained the complete passenger side fender from a scrap yard and the drivers side from a place in Ontario but it does not have the inner portion.
Old Jun 18, 2010 | 06:08 AM
The inner and outer front fender are spot welded together, I think.
Or are you talking about the plastic inner wheel "cover"
Maybe the junk yard cut the inner off so they could leave all the factory wiring and such there.
The drivers side has tons of stuff on it you have to remove to get the fender out- relays, fuse box, battery tray, ABS sensor.
I have taken a few off while parting them out.
Old Jun 18, 2010 | 10:34 AM
DIESELWRKS's Avatar
my suggestion would to find a decent one at a salvage yard that has the inner and outer already welded together. they are spot welded if memory is right there is alot of small spot welds. i would think if you could find a decent replacement this would save some time
Old Jun 19, 2010 | 12:55 AM
Dr. Evil's Avatar
You can probably order new ones from www.lmctruck.com
Old Jun 20, 2010 | 02:46 PM
Silver Ram's Avatar
pershingauto.com I think they are about $159 painted. Shipping will probably kill ya unless yer close. It's in Warransburg, Il.
Old Jun 20, 2010 | 03:32 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Don't forget the 4 bolts in the front(fender) and one bolt right underneath the truck(Attached to inner well)..Its not bad taking these fenders off...
Old Jun 20, 2010 | 03:43 PM
Dr. Evil's Avatar
Any idea how many spotwelds need to be drilled?
Old Jun 20, 2010 | 03:53 PM
I can't remember how many spot welds...But is was a few....I would say aleast 20 spot welds attaching the wheel well to fender...But it didn't take that long...used a body saw and angle grinder...
Eddy Reyes
32
Jun 5, 2007 07:36 PM
jj3500
Dec 6, 2006 02:25 PM
jj3500
Jun 5, 2006 12:42 AM
Fisherguy
Apr 13, 2006 09:17 PM
MOAGGIE
Jan 14, 2006 09:15 PM
