Cruise contol malfunction w/ ABS light on
Old Mar 20, 2007 | 09:13 AM
Mike Stowe's Avatar
While trying to diagnose my ABS light, I noticed that my cruise control isn't functioning properly. When I turn it on and set the speed, the system takes over the throttle and slowly accelerates the truck.
So my theory is that it's the ABS sensor in the rear axle. Before I go spend the money chasing guesses, can anybody confirm my suspicions?
Thanks!
Old Mar 20, 2007 | 09:27 AM
TIMMY22's Avatar
Not sure on a '99 but...
if that were a 96, sounds like 2 seperate problems.
The Cruse Control acceleration would be caused by the throttle rod being out of adjustment with the TPS.
The ABS light could be your RWSS.
Old Mar 20, 2007 | 06:04 PM
phox_mulder's Avatar
Good theory, run with it.
phox
Old Mar 23, 2007 | 12:53 PM
99farmdodge's Avatar
How do you get the throttle rod and TPS adjusted?
Old Mar 23, 2007 | 05:09 PM
Mike Stowe's Avatar
The reason I think that the two symptoms are related is because the cruise control worked properly prior to the ABS light coming on. After searching here it appears to be that the most common cause for the light is the RWAL sensor. Without taking it to the dealer to have it scanned, guessing is all I can do. So I'll throw down the $40 next week and see if it solves the problem.
Thanks for the responses.
Mike
Old Mar 23, 2007 | 06:49 PM
TIMMY22's Avatar
Figure 5 here...
http://www.dodgeram.org/tech/dsl/T_Cable/diesel_tc.htm
Old Mar 26, 2007 | 08:24 PM
Mike Stowe's Avatar
I put a new sensor in today... It fixed the CC, but the ABS light still comes on.
Old Mar 26, 2007 | 08:53 PM
Valv's Avatar
I believe the TPS is for auto only, what happens for us guys with the tough NV4500 ?
I have same cruise problem, I can set it but truck SLOWLY accelerates.
I was in IA 2 weeks ago, cruise was set at 70mph, after a while I cross a IA State Patrol on other direction, look at my speed YYYYYIKES 84mph !!! I would like to send the officer a Thank You card for being so forgiving.....
THEBIGBULLY
Feb 27, 2011 10:24 AM
BigBore050
Mar 9, 2010 11:46 PM
mr T
Feb 24, 2007 06:42 AM
fschiola
Oct 9, 2004 11:31 AM
cryo333
Mar 5, 2004 12:24 PM
