Common location for PS leak?
Old Jul 5, 2004 | 02:29 AM
dakar's Avatar
I've put it off long enough, been noticing a few small to medium drip puddles under the front end for a while now. Figured it was the puke bottle, the whole front end is covered in crud, so I let it go for a while. Last week while running home I got that horrible power steering pump squaller (like a cold 10* morning start), hit the brakes and the pedal stuttered to the floor. First thought was vacumm pump took a dump. But found the PS pump was dry, quick filled it back up and worked out the air and all is well again. Except the leak.
Is there a common failure location to look for before I get too far into degreasing and cleaning everything up to fix it?
Dave
Old Jul 5, 2004 | 09:10 AM
BarryG's Avatar
Twice on my 01 it turned out to be the bolts on the top cap of the steering gearbox. The first time 3 of the 4 were finger loose. The second time a couple of them were backed out about 1/4 of the way. Might be worth a check.
Old Jul 6, 2004 | 12:02 PM
wood_n_soldier's Avatar
I just went through this as well.. about a month ago if that long and after checking the blots on top - which were tight- and then snuging the center bolt (which I would leave to last option) I but some lucas stop leak in it and ... it stopped leaking..
while I was in there messing around I relocated the over flow bottle and cleaned everything up. I know the overflow bottle was causing a mess. The power steering leak was relativley new.
Come to think about it I never had any trouble until I had my front end alignment done. .... HHMMNNNNnn
Thundercloud
17
Oct 30, 2007 09:05 PM
mr T
Jul 27, 2006 11:50 PM
59FORD
Apr 7, 2006 12:28 AM
GlennRMK
Dec 12, 2005 04:28 PM
