anti-theft switch
Old Jun 4, 2007 | 12:05 PM
bighunterman77's Avatar
anti-theft switch
anyone know how to wire an anti-theft switch to an 02 5 speed dodge
Old Jun 4, 2007 | 06:47 PM
jl4c's Avatar
If you don't mind losing the use of your cigarette lighter you can wire it in series with your clutch pedal switch. If the cigarette lighter isn't pressed in, the ECM thinks your clutch isn't depressed and the engine won't crank. Very simple, very cheap and very effective.
Old Jun 4, 2007 | 07:12 PM
junkman1946's Avatar
This isnt electrical and I dont know if the mechanics will work. But the slickest anti-theft I think I ever saw was on a four speed Ford. If you put the truck in 1st gear and the 4 wheel drive lever all the way towards the rear the two sticks come very close to each other. Weld a heavy ring to each so they line up. Drop a padlock through the rings. Nobodys going far in 1st gear low range.
Old Jun 4, 2007 | 08:36 PM
jrs_dodge_diesel's Avatar
That is pretty slick.
One idea I've read here is to pull fuse # 9 in the power distribution box. IIRC that is the fuse for ECM power or fuel system (VP44) power. Without fuse 9 the engine will crank but never start.
Old Jun 6, 2007 | 02:51 AM
EverydayDiesel's Avatar
thats a pretty neat idea also...thanks...
Old Jun 25, 2007 | 04:57 PM
JyRO's Avatar
Couldn't you just put a switch in-line with the clutch switch? Meaning, if your switch is set to off, it doesn't matter if you push the clutch or not, the ECM will think the clutch is not pushed and the starter will not engage. Once your added switch is turned on, the 'push to start' clutch will operate as normal.
Wouldn't help in a rolling start, clutch pop situation though. But a would be theif probably would think your battery was dead and run-off.
- JyRO
Old Jun 25, 2007 | 09:13 PM
1-2-3's Avatar
Just a plain ole guy
I've been thinking about this same subject. the cig light is one of the best ideas I think i've ever heard.
Now I'm wondering how it can be pulled off with an auto trans. Hmmmmm.
SKATERHAULER
16
Feb 11, 2010 06:32 PM
Ramtough
Feb 12, 2005 10:55 AM
Don H
Jul 22, 2004 09:48 PM
handymantim
25
Jan 31, 2004 06:46 AM
GaCamper
Dec 1, 2003 08:59 PM
