Need Some Suggestions On Where To Place Anti Theft Switch
Old Jan 29, 2010 | 07:24 AM
SKATERHAULER's Avatar
looking to install anti theft switch , do I interrupt fuel cut off solenoid or starter , which is easier
Old Jan 29, 2010 | 09:45 AM
j-fox's Avatar
Starter is easy with the clutch safely switch.
Old Jan 29, 2010 | 11:12 AM
CamperAndy's Avatar
I am surprised no one has recommended inside the trigger guard of a glock.
That said use more then one. Place an obvious one and then hide one. You the seat belt switch or add one to the seat so it has to be all the back or all the way forward to set the switch. Lots of options but most only keep honest people honest.
Old Jan 29, 2010 | 12:37 PM
I have an Auto
Old Jan 29, 2010 | 05:57 PM
Hodge's Avatar
I installed one on a Suzuki Samurai years ago- I tied it into the distributor. It would crank and crank all day, but no fire. I hid it up under the dash, on the passenger side, where you had to know exactly where to reach for it. It was out of sight, so you HAD to know where it was. It was cheap, and somebody had stolen the bag with the lug wrench, lug nut key, and a spare key. It unnerved me to know that someone could take my Samurai at any time.
Old Jan 29, 2010 | 06:38 PM
Thank you and have done many cars gas cars but would like to know options with cummins diesel and auto
Old Jan 29, 2010 | 07:01 PM
infidel's Avatar
Originally Posted by skater32
I have an Auto
The wiring for the clutch safety switch is still there at the top of where the clutch pedal would have been.
There is a jumper across the connector instead of a switch.
The circuit is a ground path.
Use your cig lighter for a switch by disconnecting the positive wire and connecting one wire from the safety switch in it's place.
Now when you push in the lighter it will complete the path to ground.
If you're worried where you park take the lighter with you.
Even if they could figure it out doubt many thieves carry a lighter around with them.
Old Jan 30, 2010 | 03:09 PM
I looked under dash for clutch interrupter plug and didnt see it , can you give me a clue like color , number of wires or a pic would be great
Old Jan 31, 2010 | 12:09 AM
TRCM's Avatar
could use the cig lighter as infidel mentioned, and then tap into the parking light circuit @ the headlight switch for the 2nd.
Basically use the parking light circuit to throw a relay to give you power.
You'd have to have the cig lighter in, AND the parking lights on to be able to start it
Old Jan 31, 2010 | 08:19 AM
Simply put looked under dash and the clutch pedal connector did not jump out at me , what color wires and / or where is it hiding ?
Old Jan 31, 2010 | 08:36 AM
Hodge's Avatar
That is brilliant. Way too simple for most folks to assume is a theft deterrent.
Old Jan 31, 2010 | 10:54 AM
caper's Avatar
More reading here. Remember for a pro its gona be the first place they look . with a quick look under there they can tell its bypassed ,easy for them to short the wires out under there and off they go. I put a magnetic reed switch on mine wired to " another" wire , no magnet stuck on the switch no starty for them . If they want it that bad the'll just tow it. Altough in this case where they tryed to get mine they didn't play with the clutch cancel. Like my buddy said " the WORST PART is , it was probbly some young punks looking to go for a joy ride" . My answer , " Ya it woud make me feel alot better if they were taking it to a chop shop to sell the parts"
https://www.dieseltruckresource.com/...g-t228408.html
Old Jan 31, 2010 | 05:49 PM
infidel's Avatar
In the end it really doesn't matter what you do, if they want your vehicle bad enough they'll just winch it up on a trailer.
About all you can do is slow them down enough that they move on to another rig.
Old Feb 11, 2010 | 11:07 AM
justme-'s Avatar
disconnect the pull circuit for the fuel sol- you have to turn on key pop hood and throw the sol by hand to start. PITA at first but you get used to it. Drove with a faulty sol relay for almost a year before I had the issue resolved and had to do this- same issue ATM again so that's how I start mine...
Old Feb 11, 2010 | 12:07 PM
BigErksG2's Avatar
My bro hooked the starter lead wire through the parking light switch. It got me a week after he did it and didnt tell anyone. He turned the parking lights on and it fired right up. The cig lighter is another good one.
