About to spend money on injector removal tools - can I make these at home?
Old 12-16-2009, 08:49 PM
ted_pulliam's Avatar
With everyone's very helpful advice, I was able to just pop those crossover tubes out with a small screwdriver. I'll use the suggestions you all gave if I ever have to remove the injectors.
As you all said, the crossover tubes were pretty easy to get out. I was making it way harder than it needed to be. Numbers 3 & 5 crossover tubes were a bear to push back in. I tapped them in with the blunt end of the screwdriver.
I replaced all the crossover o-rings except #6 because I realized if that one gave me any trouble I wouldn't even have the clearance to use the screw driver and mallet to get it back in.
Anyway, I am no longer smelling diesel fuel like I did, and the area directly under the cylinder head fuel line connections looks dry. I'm glad to have that done.
Thanks again,
Tee
Old 12-16-2009, 10:35 PM
Haulin_in_Dixie's Avatar
I hope you checked to make sure you have the late injector tubes, the early ones will leak. they are throw away one use stuff.
Old 12-20-2009, 12:39 AM
Buckshotram's Avatar
pvc pipe, a washer and lug nug to pull the injectors
kawi600
01-26-2006 10:19 AM
pwrtripls1
09-27-2005 08:06 AM
CaliRam2500
08-04-2005 05:38 PM
terraj
09-09-2004 10:00 AM
georgia peach
05-19-2003 02:46 PM
Quick Reply: About to spend money on injector removal tools - can I make these at home?
