98 12v what to look for???
Old Aug 20, 2009 | 05:04 PM
tator's Avatar
lookin to get a 98 12v ctd. What should i look for and what are they worth? Its got 220000 miles 4wd 5speed.....
thanks for any and all help...
Old Aug 20, 2009 | 05:30 PM
cliff dodge's Avatar
If i where looking for a tuck like that i would check for blow by at the brethers the rocker covers prob leak feel for cluch slip check the diffs for leaks same as trans and transfer i would also check for any power up grades becuse of the miles and if possble find out how the truck was used all its life was it worked hard or ez life towin a camper around?
Old Aug 20, 2009 | 05:39 PM
tator's Avatar
the guy that has it now dont pull much but not sure about before him. no power adders that i know of.
any common problems to look for? like the big stuff.....
thanks cliff
Old Aug 20, 2009 | 07:10 PM
STate's Avatar
https://www.dieseltruckresource.com/...0+screen+clean
Old Aug 21, 2009 | 06:02 PM
hey tator state is 100% right i cant think of any thing after that wow guess i should of checked the for a post like that first
Old Aug 21, 2009 | 06:55 PM
96_12V's Avatar
in additon to existing thread:
--Front ends on 4wd are troublesome. Check ball-joints, trac-bar. Replace as needed.
--Check condition of front & rear diffs, lube properties, driveshafts, etc.
--Check doors & under bed for lower-level rust areas.
--Check to see if KDP has been tabbed (just do it).
--Check condition of wallet - insure that you have 20% reserve for unexpected repairs.
220k isn't much on the engine, it's not bad on the truck either depending upon use. I had a South Bend clutch installed at 290k and it was $665 including labor. Otherwise; a radiator, steering box, upper & lower ball joints, pitman arm & idler, starter, rear drum rotors & front disk rotors have been the major expendatures. Note that things like brake rotors are much more expensive on these trucks than what you may be used to.
Old Aug 21, 2009 | 07:49 PM
GUMP's Avatar
Mine is an 01, but similar mileage, I changed starter, brake pads, rear abs sensor and the lift pump, had my ball joints checked and I have put about 14,000 good miles with no problems. Just added 255/85 tires and they seemed to help the traction and gearing.
Old Aug 29, 2009 | 11:59 AM
kandgo's Avatar
Check to make sure it does not have the 53 stamped block. If it does, run away!!
bsj04
Jun 30, 2007 03:31 AM
Dodge@KY1997
21
Feb 4, 2007 08:00 PM
nirion
Apr 24, 2005 06:10 PM
SmokinDodge12V
22
Nov 23, 2003 09:50 AM
