what trans do ihave ?
Old Oct 15, 2006 | 09:24 AM
dunewaggon's Avatar
i need to service my trans and i don't know what autotrans in it ? I've seen two different numbers for auto trans and if any one knows what filter and gaskets i need from napa and also what trans fluid and how much ? and if theres any other things that needs to be done when i'm in there. thank you
Old Oct 15, 2006 | 11:44 AM
J BODY's Avatar
...first of all welcome fellow desert rat. On your parts... fill out your signature and we'll be able to see your "make, model, year, etc....". On parts. I would go to the dealer and get the filter and reusable pan gasket. I've had the pan off my truck three or four times and the race car about seven with ZERO leak issues. It's a nice piece.
Old Oct 16, 2006 | 08:23 AM
dunewaggon's Avatar
trans ?
sorry about not telling everything about truck
1999 2500 4x4 quad cab, auto trans,straight pipe , superchip, I hope thats enough info thanks
Old Oct 16, 2006 | 08:44 AM
Mcmopar's Avatar
you have the 47RE
Old Oct 16, 2006 | 07:48 PM
dunewaggon's Avatar
trans help
thanks for the info. is there a band adjustment some where and if so is there a diagram on the web that i could look at and print out to have when doing ?
and what trans fluid is best for the dodge taht works good that is not a synthetic ? thanks again for the help
Old Oct 17, 2006 | 07:54 AM
Mcmopar's Avatar
There are two bands to adjust, the front one is on the drivers side of the case, up above the shift levers, the rear band must be adjusted with the pan off the transmission. You torque these to 72 INCH/lbs and then back them off from there. These specs did differ a bit from year to year. You can find this info in a Factory Service Manual (FSM). Chrysler recommends ATF +3 or +4 depending on the year. The +4 is a synthetic oil. I use it all the time and buy it at NAPA, it is about 3.70 per quart. I use the Valvoline stuff, the part number is VV 346.
Old Oct 17, 2006 | 09:14 AM
dunewaggon's Avatar
trans service
thanks for the info on my trans. how much fluid do i need ? what filter should i use ? is there any pictures of the band adjustment that i can get?
Old Oct 17, 2006 | 04:53 PM
scottsjeeprolet's Avatar
If you are just changing the fluid then you'll need about 7 quarts. Get the OEM filter.
The band adjustment procedure is in the tech section.
Everything you need is all here on this site and FREE!!
Old Oct 18, 2006 | 08:28 AM
dunewaggon's Avatar
trans
thanks for the info. i forgot to ask what fluid is best for the dodge trans ? thank you
Old Oct 18, 2006 | 08:51 AM
Mcmopar's Avatar
See my last post.
Old Oct 18, 2006 | 08:56 AM
dunewaggon's Avatar
trans
sorry about that i should have read a little closer before posting. thanks for the info
Old Oct 18, 2006 | 11:00 AM
RowJ's Avatar
I believe your truck calls for ATF+3... But I recommend synthetic in stock trannys....actually in all autos, but especially in stock, and especially in the hot southwest!
JMO - RJ
Old Oct 18, 2006 | 11:17 AM
2500's Avatar
go with ATF 4+ valvoline was on sale at napa for $3.49 qt
highly recommend patially dropping valve body to drain out more fluid. you can change out aprox. 9qts VS 4qt without dropping VB.
don't follow spec's on haynes manual. there's several links that gives good spec's . both frt and rear forks should have aprox. 1/4in adjustment if you used proper spec's.
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Old Oct 18, 2006 | 11:14 PM
dunewaggon's Avatar
trans
Thanks alot for the info 2500 the dieagram will help alot thanks again
zacx
Jan 24, 2010 04:02 PM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
