What is a Trac-lok differential???
Old Apr 12, 2010 | 12:00 PM
imbodie's Avatar
I'm about to change the gear oil in my rear differential, I've done this one time before and did not add a friction modifier. I'm looking on dodgeram.org and it says if I have a trac-lok diff that I needed to add the friction modifier.
Do I need the friction modifier? How do I know?
Suggestions??
My truck is in signature.
-Tim
Old Apr 12, 2010 | 01:30 PM
RowJ's Avatar
If you have a 5 speed, you do have a Trac Lok Dana 80 rear end.... that is if you have limited slip differential.
There is a metal tag on one of the differential cover bolts that will tell you.
Can also get the info from a dealer by taking your VIN # to a Parts Dept and asking for a "Build Sheet" on your CTD.
Should be free.
Some higher quality gear lube had FM included.... others don't. Tight turns (figure 8's) in a Walmart parking lot will tell if yours is binding or not. If so, needs more FM.
RJ
Old Apr 12, 2010 | 11:09 PM
dozer12216's Avatar
LS needed for track-lok.
Old Apr 12, 2010 | 11:19 PM
mstep3's Avatar
Suggestions??
-Tim
I just recently re-did my front and back diff & put Royal Purple Max-Gear in it. It's really good stuff & is supposed to really keep the heat down & protect the gears. Price is kind of high compared to the others though. It's not necessary to put friction modifier in this is you use Royal Purple. If you tow a lot I believe you're supposed to use 75W 140.
http://www.royalpurple.com/gear-oil.html
SkyHarborCowboy
14
Apr 23, 2009 01:01 PM
Dodge89W250
Feb 24, 2008 05:15 PM
Dodge89W250
Feb 9, 2008 05:34 PM
brooks829
Jan 21, 2006 12:06 PM
NWDave
Jan 25, 2003 06:03 AM
