trac lok posi
Old Feb 9, 2008 | 04:41 PM
Dodge89W250's Avatar
trac lok posi
if you have the trac lok posi out of the truck can you turn the spider gear with your hand? because i bought a trac lok and i cant spin the spider gears.. does that mean i need to rebuild it?
Old Feb 9, 2008 | 05:07 PM
user name's Avatar
You shouldn't be able to turn them by hand. If you could it would mean the clutches are shot. make sure you run the limited slip addative when you get it in.
Old Feb 9, 2008 | 05:11 PM
so i shouldnt be able to turn them?
Old Feb 9, 2008 | 05:19 PM
user name's Avatar
nope the spider gears with clutches behind them is what "limits the slip" if you will. by making it harder for the spider gears to turn it make the wheels both want to spin the same speed. when you pull the stock one it should be very easy to move the spider gears that the difference in them. the weight of the truck and leverage of the tires will get them to move at different speeds going around a corner. it sounds to me like it's doing what it should.
Old Feb 9, 2008 | 05:34 PM
ok thank you.. i bought it off ebay for my truck i got a 89 w250 318 and it didnt have posi and i wanted posi so i got it and just wanted to make sure because my friend said they should spin... thanks again
SkyHarborCowboy
14
Apr 23, 2009 01:01 PM
Dodge89W250
Feb 24, 2008 05:15 PM
Eskimo
Apr 15, 2006 09:27 PM
Eskimo
Jan 25, 2006 09:54 AM
brooks829
Jan 21, 2006 12:06 PM
