What oil and oil filter?
Old Mar 9, 2005 | 12:20 AM
Wolff's Avatar
I am just curious as to what brand and type of oil most people are running and what brand of oil filter?
Old Mar 9, 2005 | 12:23 AM
Big Smoky's Avatar
I have been using Chevron Delo 15w-40 in all the CTD's I've owned and it hasn't let me down, and I run my truck hard. I use a WIX filter with it. It's a good oil IMHO.
Eric
Old Mar 9, 2005 | 12:29 AM
smokindog's Avatar
Rotella T with Fleetguard Stratopore Filter
Old Mar 9, 2005 | 03:43 AM
Supermod56's Avatar
Delo, Rotella, they all work good, just make sure you use the Fleetguard filter!!!!
Tom
2001.5 2500 4X4 5-Spd LB QC Black. DD TTPM, DD Stage-1's, Catcher ECM, AFE, Bully Dog 4" pipe, ATS Exhaust Manifold, JAKE Brake w/shifter switch, Geno's Banjo's, 3 Autometer's on the A-Pillar, Gear Vendor's O/D, Firestone Air Bags, Redline Oil throughout.
Old Mar 9, 2005 | 05:47 AM
CTD NUT's Avatar
I use Rotella T and a Fleetguard #3894 (Stratapore)......oil changes every 10,000km (6,000 miles).......
Old Mar 9, 2005 | 06:58 AM
Geico266's Avatar
Do a search and you will have hours of reading.
Old Mar 9, 2005 | 08:06 AM
Mopar1973man's Avatar
I agree with the search...Lot of good readin'
Exxon 15W-40 or Phillips 66 15W-40 - 5 gallon buckets
Fleetguard filters...Oil, Air, and Fuel
Old Mar 9, 2005 | 12:24 PM
HOHN's Avatar
I would say that the Stratapore filters are demonstrably better than others.
For dino, you can't go wrong with Rotella, Delvac, or Delo. They are ALL CI-4+ rated now, and all are "million mile" oils in a modern CTD.
I blend in a little syn because I use my truck in a horrible way-- lots of cold starts and short trips. I feel the syn helps reduce wear in this type of use profile, because I see faster oil pressure rise and the engine's much happier when cold.
Synthetics ARE better at lubricating the engine, but you'll have to ask yourself if good enough is good enough. CTDs have gone over a million miles on Rotella and Delvac, so is synthetic necessary?
Only you can decide.
I spent a bunch on this truck, so I'm not going to pinch pennies on oil selection. Redline isn't cheap. I have, however, used it now for almost 100K on my Nissan, and the engine is an exceptional condition, even after operation in a lot of temp extremes (-40 to +105). I like the Redline stuff. Your mileage may vary.
Justin
Old Mar 10, 2005 | 01:25 AM
Wolff's Avatar
I am thinking hard about switching my tc, tranny and rear end to red line and running synthetic in the motor. I always used Rotella in my other CTDs so I will probably just continue with this one. It has 81k on it so I might just go with the synthetic Rotella.
Old Mar 10, 2005 | 03:59 AM
jrs_dodge_diesel's Avatar
For oil click here. That link will take you to a oil preference poll and you can see what most people here use.
I personally use Chevron Delo 400 and have no complaints about it. I recently could not get Delo 400. I looked around some and found Valvoline Premium Blue. Its regular dino oil for diesel engines that Cummins endorses. So far so good with it, and it may just replace Delo 400 as my regular oil.
As for filters most everyone here at DTR will reccomend Fleetguard Stratapore filters for both your oil and fuel. If you can't get the Stratapore then a normal Fleetguard will do.
Old Mar 10, 2005 | 12:07 PM
slowerthanu's Avatar
Are the dealer filters Fleetguard?
Can I pick up the Fleetguards at Cummins Dealers?
Old Mar 10, 2005 | 12:25 PM
bluebull's Avatar
Yes, fleetguards can be bought at cummins.
The Mopar filter is just a rebadged fleetguard.
Subliminal
Jun 16, 2011 03:26 PM
vegashd
Jul 15, 2007 12:24 PM
danc46
Jan 6, 2007 05:24 PM
roc155
23
Mar 9, 2006 06:44 AM
turbo59pwr
Jul 9, 2003 04:24 PM
