Valve adjustment ???
Old May 8, 2005 | 08:27 PM
NHdodgeman's Avatar
My father has an 02 3500 CTD with 75K on it. Is it time to adjust the valve train yet?? The Cummins site said to adjust @ 150K but did not specify what motor. Any responses would be greatly appreciated
Old May 8, 2005 | 09:12 PM
fschiola's Avatar
The owners manual on my 2000 states 150,000 miles before running the overhead. It also says 135,000 miles for severe service. You might find this useful. Click here
Old May 8, 2005 | 09:24 PM
NHdodgeman's Avatar
Thanks Fschiola thats a handy little page there.
Old May 8, 2005 | 09:27 PM
fschiola's Avatar
Here's one for your '91
http://dodgeram.org/tech/dsl/maint/1st_Gen-12v.htm
Old May 8, 2005 | 09:43 PM
TORQUE's Avatar
I checked mine at about 100,000kms(24v), and just about all were out on the upper end of specs. I set them all to the tight side of specs, and it quieted it down a lot. Cummins allows for a wide gap for both intake and exhaust and as long as it falls within that range they say it's fine, unlike older 12v's. Unless it is clacky you could leave them until about 160,000kms as specified in manual. Setting them to the tight side will increase power, lessen smoke, quiet down engine and give slightly better mileage. Be cautious if you set them yourself be precise, or you'll bend pushrods or valves if set too tight. That's the time to slam in bigger injectors without him knowing, and seeing his face when he takes it out for a twist.
Old May 8, 2005 | 10:01 PM
NHdodgeman's Avatar
HA HA wouldnt that be a barrel of laughs. Hes lookin to do some mods for a little bit more power when towing.
Old May 8, 2005 | 10:05 PM
NHdodgeman's Avatar
So I guess we will hold off on the adjustments for a bit.
Thanks to all .. Much appreciated
Old May 8, 2005 | 10:11 PM
fschiola's Avatar
Torque, did you have to replace the gasket?
Old May 8, 2005 | 10:45 PM
BigBlue's Avatar
The valve cover gasket is reusable. I've had mine off a dozen times and it still seals great.
Old May 8, 2005 | 10:46 PM
HOdiesel's Avatar
Well, this sounds like what I need to do! I am getting pretty good smoke during acceleration. How hard is it to adjust the valves? Can it be easily done in a weekend? My truck has 185,000 miles on it.
Old May 8, 2005 | 11:06 PM
fschiola's Avatar
Go to the top of this page and click on "tech facts". Then "24 valve ISP 2nd gen". Then"valve lash setting procedure". Should be what you're looking for.
Old May 8, 2005 | 11:21 PM
HOdiesel's Avatar
I can't find the "valve lash setting procedure" in the "24 valve ISP 2nd gen" area. I'm hoping it is a simple procedure. I have too many hobbies .
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
