Valve Adjustment
Old Nov 25, 2004 | 05:55 PM
perk's Avatar
Valve Adjustment
I am going to adjust my valves tomorrow. Are the tollerances the same for the 24v as the 12v? Is there anything different to job from the 12v?
Old Nov 25, 2004 | 06:42 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Check our Tech Facts Button at the top of the forum page for great info like this:
24 Valve ISB - 2nd Gen - Engine and Drivetrain : Valve Lash Setting Procedure
Old Nov 25, 2004 | 07:25 PM
Geico266's Avatar
I checked mine after 160K miles and there was nothing to adjust. Even the manual says leave them alone unless you have worked on the valve train.
But it never hurts to check. While you are there look at your fan blades. If you see cracks replace it. Mine just came apart and caused about $1,000 in damage.
Old Nov 25, 2004 | 07:47 PM
Kyle Graham's Avatar
ouch 1,000 bucks man that sucks
Old Nov 25, 2004 | 11:39 PM
perk's Avatar
Thanks Shovelhead.
Old Nov 26, 2004 | 01:19 PM
perk's Avatar
Can anyone tell me how the plastic cover on the geartrain cover comes off.
Old Nov 26, 2004 | 06:53 PM
Geico266's Avatar
The plastic cover is threaded. Turn it to the left. Make sure the gasket is in good shape whne you put it back. I used a strapwrench, but its not on very tight.
Old Nov 27, 2004 | 12:37 AM
thumper 549's Avatar
all the isb come from the factory LOOSE..want me to do the math for you?? .01 loose equals .01 retard on the cam and so on .........
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
