dead 2001 dodge diesel
Old Nov 26, 2004 | 07:41 PM
bcnu's Avatar
My 2001 2500 will not start.I connected a fuel pressure gauge to the fuel system at the injector pump,turned motor over i had mabe 8lbs of pressure for just a instant then the pressure went to 0,truck will not even try to crank.any help would be appreciated.
Old Nov 26, 2004 | 08:59 PM
firestorm's Avatar
Check your fuel level, check the fuel filter condition, and try bleeding the system. It sounds like you probably have a bad lift pump, and I don't even want to say what else might be bad. Try the above first.
Old Nov 26, 2004 | 09:20 PM
Dr. Evil's Avatar
when you bump the starter can you hear the lift pump run?? (should be over 20 seconds)
Old Nov 27, 2004 | 06:21 AM
bcnu's Avatar
I changed the filter,drove 390 miles,killed the truck,tried to start it,it turns over ok but does not try to start.I can hear the lp for a couple of seconds.With the fuel pressure gauge connected at the injector pump,when i turn the key on i get about 8 lbs fuel pressure,when i turn the motor over the pressure goes to 0.Thanks
Old Nov 27, 2004 | 08:02 AM
Dr. Evil's Avatar
dont just turn the key on - you have to bump the starter - so that is engages the starter but doesnt start the truck. The LP should run for around 23 secs.
rattlebox01
Nov 6, 2009 12:28 PM
Mariner 250
Oct 10, 2006 03:31 PM
Rick757
13
Aug 18, 2005 03:08 AM
Holycack
Jun 27, 2003 03:26 AM
gs
May 5, 2003 10:19 PM
