Truck creeps at stop light!
Hey gang-
just got another 99 24 valve 4x4 truck today, & It stalls when I put it into gear with the brakes on.
If I start it, put it in gear without the brakes it will almost stall, but if I give it a little gas it will go ok. Drives down the road fine, shifts a little late into 2nd at first, but shifts normally after that.
When I come to a stoplight it idles down like it's going to stall, but it will push against the brakes & darn near push me through the intersection while on the brakes. Makes me think it's torque converter, but it does work fine on takeoff & normal driving.
Another problem I have I think is the alternator, because it won't stay charged very long, & Usually needs a jump. Going to buy a battery load tester, & take the alternator to advance & have them put it on the tester.
Any ideas??
Thanks
Any ideas??
Thanks
Hey gang-
Any ideas??
Thanks
Any ideas??
Thanks
If you have an original alternator, your best bet is to buy a kit and rebuild it. I went through two alternators from auto zone that were bad right out of the box before buying a bosch alternator that required me to take the pulley off the original. Unfortunately, I had already turned in the core. The same goes for starters.
I'm not totally sure, I haven't rebuilt one, I'm only speaking from what others told me after the fiasco I had with mine, and I've seen rebuild kits online. But as far as the bearing goes, I would rebuild everything while you have it apart already. Hopefully someone else will chime in who has more experience than me.
Usually you just need the brush kit.
I buy mine from
Larryb - LarryB's Brushes for Dodge Diesel Denso alternator, 1989-2007
But first you need to make sure that you still have the stock Denso alternator.
About the truck "pushing"- do you notice the same pushing if you pull it into manual first gear?
Did you take a look at the TC through the little inspection hole on the bottom of the bellhousing? It would be interesting to know if you have a discoloration or overheated paint on the surface with the lugs that are used to bolt the TC to the flexplate.
I buy mine from
As far as diagnosing a shifting problem, I would just disconnect the field from the alternator and take it for a drive. If the transmission problem remains, it would eliminate the alternator as a suspect.
Hey guys-
bought a new alternator for the truck, ran a ground wire from frame bolt of alt. to truck fender wall (bare metal).
Fired it up today & alternator was reading 40, then went down to 38.5 volts, & battery was only reading 11.5 v at the terminals & the batt leads. Checked it a few times & got the same-What gives? Batteries are used & about dead; would new batteries fix that? Really don't wanna shell out another 300 or so for batteries
You're kinda up against the wall there, if you have a bad battery or a dead cell or two you will need batteries anyway.
I'd get them tested rather than throw parts at it off a hunch.....
Hey guys-
Hey gang-
Any ideas??
Thanks
Any ideas??
Thanks
bullrider9800
19
Aug 25, 2008 08:14 PM
slivertruck
25
Nov 8, 2006 08:35 PM
royta
Nov 6, 2006 08:19 AM
